Hello.
I need the specs on hub centric spacers for the s13 hub. 4x114.
Going 25mm front and 30mm rear. Also the spacers will bolt on to the hub then have new thread for the wheels
Any help will be awesome! Needed asap
Spacer specs
Spacer specs
Re: Spacer specs
Thanx got someone who is gonna make them, a favour for a favour type deal haha. Just need the specs for him to do it.
Re: Spacer specs
Kriek, what is the problem?
You have the PCD, the thickness and you can just measure the spigot size to be sure but is should be 66.1mm IIRC.
Re: Spacer specs
Its the spigot size I needed. As I don't have something accurate to measure it with:shock:Enzio wrote:Kriek, what is the problem?
So just need to confirm the 66.1mm size then
