Page 1 of 3
ecu options
Posted: Fri Jan 11, 2013 6:52 am
by smash!!
morning guys just picked up my 1992 nissan 200sx with a ca18det . \
im kinda new to this car so wanted to know a few things i have a dicktator lying around its an std i have a brand new t3/t4 garret hybrid turbo, walbro fuel pump, fuel surge tank, bigger ic, new boost pipes, new hks dv,tial 38mm wastegate, just looking for a top mount turbo mani, new 76mm mm down pipe.
car is still 100% stock can i run the dicktator std on the ca18 and then add all these mods and boost .9 bar ? i will be saving up for new forge internals i would like 200wkw or a bit more couldnt hurt will i be able to achive 200wkw on stock internals .
thanks in advance
Re: ecu options
Posted: Fri Jan 11, 2013 10:30 am
200 is reachable on stock internals but dont think on stock injectors and anything over 200 on stock internals is not to safe for you motor is the diktator a wasted spark?
Re: ecu options
Posted: Fri Jan 11, 2013 10:37 am
by Ero_sennin
i would say skip the dicktator and use nistune to tune the stock ecu
much less hassels, everything will still work, no butchering your wiring, and no stupid hal pickup
Re: ecu options
Posted: Fri Jan 11, 2013 3:45 pm
Use Nistune. The std internals can handle 200wkw, but just not by adding boost. If you want the motor to last you'll have to look at watermeth.
Re: ecu options
Posted: Mon Jan 14, 2013 7:55 am
For 200wkw you will have to increase injector size, 440cc-550cc will do the trick.
Re: ecu options
Posted: Mon Jan 14, 2013 8:08 am
by smash!!
ok thanks guys , no the dicktator is the standard type
Re: ecu options
Posted: Mon Jan 14, 2013 8:12 am
by smash!!
who does the nistune ?? i stay in krugersdorp .
Re: ecu options
Posted: Mon Jan 14, 2013 8:15 am
Thats the tricky part....
Re: ecu options
Posted: Mon Jan 14, 2013 2:48 pm
by smash!!
haha why is it tricky? how much support for the product is there?
Re: ecu options
Posted: Mon Jan 14, 2013 2:53 pm
by smash!!
Re: ecu options
Posted: Mon Jan 14, 2013 3:13 pm
As far as I know there is only some forum members that import it themselves, pay the licence and install and tune themselves, I don't know of a tuner, so they would be your only local support in regard to installing and tuning.
Re: ecu options
Posted: Mon Jan 14, 2013 3:34 pm
by Pinkfluffybunnys
NISTune FTW
Re: ecu options
Posted: Mon Jan 14, 2013 3:44 pm
Pinkfluffybunnys wrote:NISTune FTW
That would be one of them....and the first I believe.
Re: ecu options
Posted: Mon Jan 14, 2013 3:51 pm
by smash!!
Thanks for the replys , @ pinkfluffybunnys could you quote me on the nistune system PLEEEEZZZ
Re: ecu options
Posted: Tue Jan 15, 2013 3:24 pm
If you dont come right with PFB, I'm more than likely gonna get stuf from Nistune in a month or two.
