Spark Plugs
Spark Plugs
hi guys where can i get good quality Spark Plugs from ive had 2 NGK plugs die on me within two weeks im using bcpr7ez i think
- k.y.l.e.
- Real Name: kyle
Re: Spark Plugs
Hey bud those are awsome spark plugs i use them on my sr they bcpr7es, strange they last two weeks in your car maybe get a set of ngk iridium spark xi plugs for your car then, if that does not last then i really dont know, hope it helps budy.
Re: Spark Plugs
If your sp only held 2 weeks you either have a oil or fuel fouling problem, normally cars with aftermarket management systems is not set up properly on idle, thus starting the engine for a while to shift the car or just run for a while results in one or more plugs fouling over a period of time, you might end up buying new plugs and sit with the same problem.
Re: Spark Plugs
my car ran for a bit with timing out then stood for a month then after that within two weeks 2 bmbed
Re: Spark Plugs
where can i get iridium plugs from and is there a specific size i need
- Charlvdw
Re: Spark Plugs
I'm thinking about bringing in some again(for the zx), think it came to round R500 for 4 last time, more then a year ago tho. But if you interested pm me and I'll see what I can get.
Re: Spark Plugs
I installed mine not even 3 weeks ago when I installed my head and reconnected everything, since then drove with it once and started a few times to try and sort idling with new injectors, 1 plug died on me last weekend.SonOfAnarchy ZA wrote:my car ran for a bit with timing out then stood for a month then after that within two weeks 2 bmbed
