Running Rich and Horrible Fuel Consumption!!!
- Real Name: Renier
Re: Running Rich and Horrible Fuel Consumption!!!
have a look if your feul lines are not swaped around
- Real Name: Renier
also is it stock ecu? any spoeg and plak like dastec pigy back?
Everything is stock on the car.... Think I will just pull this CA and fit SR
- poizen
- Real Name: Mical Mackay
yea thats the right mentality thinking right there
fit a bigger motor
with a dicktator batch firing ecu
and hope to get better fuel
its not your motor causing the problem
if you walking in the shop and get a erection dont blame the penis blame the brain it told it to
fit a bigger motor
hahaha choppoizen wrote:yea thats the right mentality thinking right there
fit a bigger motor
buddy from many years experience fixing pc boards plcs ect i learnt one thing...... i used to get a drive or what ever that just would not work i had checked everything it all measured and tested fine, 4 out of 10 times i had missed something and the other 6 out of 10 time was something that tested or measured right but failed in the circuit. its time to start replacing things!!
1. Engine coolant temp sensor
2. MAF
3. ECU
ect
not even Nissan could find the problem!! took injectors out today on the rail! looks like it squirts a bit to much. like a real large amount of fuel at a time. plugs get wet all the time and stays pitch black!
- poizen
nissan dont even know what these cars are so going to them is a waste
take injectors to get tested and cleaned while they out
