CA18DET questions
CA18DET questions
Hi guys probably stupid questions so please be patient got to learn some how.
1. there is a rubber hose going to the fuel return pipe.....What would happen if that had a leak in it?
2. What would happen if one of the cables on the throttle positioning sensor is off?
Enzio
Re: CA18DET questions
Post by Enzio »
SonOfAnarchy ZA wrote:Hi guys probably stupid questions so please be patient got to learn some how.
1. It would leak fuel
2. It would not know throttle position/not engage idle switch
it doesnt seem to leak fuel but i hear a hissing sound as if it is loosing pressure
NIZAN-R
Real Name: Renier
Post by NIZAN-R »
2. If you unplug it your idle will go up
if not set corect also does not know proper throttle position and can be heavy on feul
