SR20 pops Dipstick under boost
Re: SR20 pops Dipstick under boost
Fokstrot wrote:I got the dipstick to stay in
did you replace the o ring?
Sorry guys i understood wrong i was reffering to puting the dip stick were it goes on to the bottom of the block and put a thin film of rvt sealent on the ridge of the dip stick were it goes into the block.
Fokstrot
Newbie
Real Name: Frans
Post by Fokstrot »
Yes i did replace the oring but with one slightly bigger than the original. Its kwl kyle dont sweat it! :)
NIZAN-R
Real Name: Renier
Post by NIZAN-R »
Fokstrot wrote:Sorry i dont know these engines very well. Can you please tell me what the pcv valve looks like and where it is located? Thanks guys i really appreciate all your time and effort.
did you come right fokstrot
Fokstrot
Newbie
Real Name: Frans
Post by Fokstrot »
no i did not. pretty sure that the head gasket went. :( Still have to do compresiion test to confirm. Just very busy at this stage, havent gotten round to it yet
where do you stay? dont think its gasket he put in a cometic one hard to blow those at low boost heres the link to the build on your car
http://200sx.za.net/phpBB3/viewtopic.php?f=6&t=7330
300sx
0.8 Bar Boost
Post by 300sx »
k.y.l.e. wrote:Hey buddy sounds like you getting compression in your sump wich is due to piston ring issue maybe piston rings worn out and piston ring end gap is to big and compression is escaping into your sump, also check the pcv valve. A bad valve causes this.hope this helps buddy [smilie=200sx_200sx.gif]
+1
got a gut feeling somebody saw you coming..
300zx fairlady 1991
200sx s13 with vg30det @ 1bar
what future problems will this issue cause?
