sr20 strip down and build up UPDATED
- POWDER
- Real Name: Mike
Re: sr20 strip down and build up UPDATED
OK, then for function, you have 2 lines coming from the break cylinder, one for front F and one for rear R. The line from F needs to be T-pieced to the 2 lines the come out the ABS pump marked FR + FL. The one marked R needs to then be straight linked to the line R from the ABS pump. Then your done.... You will need propper fittings though.... Will see if I have a Pic for you.... PM me ur email address and BBM pin
Thanks dude Can't u watsapp it buddy?
- 0.9 Bar Boost
- Real Name: ????
abs has its own ecu in the back right hand side behind the panel... std ecu will be fine to take it out.
clean sr kyle
clean sr kyle
