CA18DET upgrade question
Posted: Mon Jun 25, 2012 10:35 am
Hi guys, when i have the cash i would like to give my CA18 some more power without breaking the motor or the bank, i dont want to spend money on engine itself because one day i would rather install SR20 S14, heres whats done to my engine already in terms of performance.
- BLITZ full alluminium racing radiator
- 76mm straight through with a single back box on the end
- cone filter
- Walbro Turbo intank feul pump
- boost cut disconnected
- OEM RB25 feul pressure regulator (could be same as CA18det?)
- Atmospheric BOV on cold side
The motor is also a low milage import that was only installed end of last year, its really healthy and compression was on spec last i checked, no burning oil or leaks.
So my next plan was T28 turbo and FMIC, would my stock injectors cope with a T28 at 0.6 - 0.7bar and what sort of power gains can i get, stock CA18det is 126kw and 220nm according to most sources, is this at the flywheel? and if bigger injectors are required would my stock management be able to run bigger injectors or would i then need nistune or something?
- cone filter
