Alternative - SR20DE Cams and gears
Posted: Sat May 12, 2012 11:45 am
by djtreble
If I can't com eright with a VCT cam gear then has anyone got and SR20DE cams and cam gears in good condition?
Thanks
Dylan
Re: Alternative - SR20DE Cams and gears
Posted: Sat May 12, 2012 4:26 pm
by phoenix s14
Dude fwd DE cams fit and work and the STD SR20 gear also fits. Just go to a engineering shop and buy a high tensile bolt. Check the Nissan owners club forum for cams. Or lock your cams in the advanced position with the STD SR20 non vct gear. Works better than DE till 6000rpm. If you get a DE cam you need a highport SR20DE cam from a sentra - they are 248deg and 10mm lift :wink:
