Rwd engine the same as Fwd?
Posted: Fri May 04, 2012 7:45 pm
by oki
Hi there everyone, I have just collected my SR motor for my Lotus 7. It is a RWD motor (S14- variable intake cam) I have tried to search but came up empty-handed - can I use the local gasket sets, timing sets that I see from time to time on Bid or Buy? Any help will be appreciated.
Okkie
Re: Rwd engine the same as Fwd?
Posted: Sat May 05, 2012 4:49 am
by NIZAN-R
you will need to get s14 gasket set
only some gaskets will fit from s13sr20det/n14sr20de
Posted: Sat May 05, 2012 5:00 pm
by phoenix s14
most of the gaskets fit except the head gasket which I recommend you use a cometic anyway (even if it is a non turbo) on NA motors the victorheinz gasket set has most of the stuff but on the turbo the exhaust gasket is a layered metal item. Just buy a cometic gasket set for it. It is R3000+/- and well worth it. :wink: Can get one from rezlo, importparts etc etc... will need to be shipped in and some waiting will be required...
