sr20det new and used parts.
Posted: Sun Feb 26, 2012 5:49 pm
All below still available.
Nismo 740cc injectors *4 R3200 used for 5000kms.
Supertech valve guides inlet and exhaust R800(new)
Supoertech valve stem seals R300(new)
Brian Crower Exhaust valves R1300(det)(new)
A set of brand new hydraulic lifters R1000
(old ones R400)
Brand new rocker arms R250each
std valve springs ?
s14 steering wheel with airbag ?
std headbolts and main bolts ( only loosened once from factory motor before installing arp)
std 370cc sidefeed injectors R800
Bare s14 head and cover ( no valves, no springs not even guides, only caps ) R1300
std s14 airbox , turbo pipes intercooler etc.
std s14 rear wing R300 (maroon)
used suspension parts coil springs shocks etc , removed when installing coilovers etc,
a new set of pineaple rings Megan to lock rear subframe in place R400
Brand new M3 type side mirrors to fit s14 electric R450(powercoated metallic grey)
two used s14 sr20det oil pumps, one 90000km R400
Other one 8000kms R800.
1 time used 87mm 1.5mm thick Cosworth headgasket R400
Brand new Cosworth 87mm and 1.1mm thick headgasket R1400
s14 std intake manifold ?
Complete sr20ve neo vvl bottom end and intake manifold, exhaust manifold etc.( only removed oil pickup and front spacer, easy to get)
R2500.
private me if interested !!!!!!!!!!!!!!!!!!!!!!
I
(old ones R400)
std valve springs ?
R2500.
I
