Why is my CA18 Running Rich
Posted: Fri Feb 17, 2012 12:07 am
Hi guys, after alot of trouble shooting and long hours we've gotten my car running much better, heres all we've done:
New timing belt and other belts
Timing set to spec
Cam angle sensor 15 degrees
Walbro 255lph feul pump
Sard adjustable FPR set to 2.5 kg/cm2 during constant pump test
BCPR6ES plugs set to 0.8mm gap
I took out the plugs today and they were black all over, not wet atall, and those plugs have probably done around 100km now, see the pic below even though its crap quality:
With the car idling the feul pressure sits at 2kg/cm2, the vacuum source i used was the vacuum nipple on the back of the intake, because the stock vacuum hose from that solenoid didnt seem to do anything as the pressure would not climb if you gave revs.
All else seems fine, what could it be? Could my airflow meter be faulty or need adjusting, any info would be great thanks
Timing set to spec
