Nissan Skyline brake disc and caliper information
MODEL SIZE TYPE
R32 T 280mm x 26mm (single pot sumitomo caliper)
R32 GTS-T (early) 280mm x 26mm (single pot sumitomo caliper)
R32 GTS-T type m 280mm x 30mm (4 pot sumitomo caliper)
R32 GTR 296mm x 32mm (4 pot sumitomo caliper)
R32 GTR VSPEC 324mm x 30mm (4 pot brembo caliper)
R33 GTS-25 280mm x 26mm (single pot sumitomo caliper)
R33 GTS-4 280mm x 26mm (single pot sumitomo caliper)
R33 GTS-25T 296mm x 30mm (4 pot sumitomo caliper)
R33 GTR 324mm x 32mm (4 pot brembo caliper)
R33 GTR VSPEC 324mm x 30mm (4 pot brembo caliper)
R34 GT 296mm x 30mm (4 pot sumitomo caliper)
R34 GTT 310mm x 30mm (4 pot sumitomo caliper)
R34 GTR 324mm x 32mm (4 pot brembo caliper)
Z32 NA 280mm x 26mm (4 pot sumitomo caliper)
Z32 TT 280mm x 30mm (4 pot ali sumitomo caliper)
S14, S15 280mm x 30mm (4 pot sumitomo caliper)
R32 GTST
Master Cylinder diam (mm) 25.4 area 506.71mm²
Front Caliper Piston(diam x qty) 40.4×4 = 5127.58mm²
Front rotors (diam x thk) 280×30
Rear Caliper Piston(diam x qty) 38.18×2 = 2289.78mm² ratio FR = 2.239
Mounting Hole Diameter Approx 4.5 inches
Rear Rotors (diam x thk) 297×18
Total area 7417.36mm²
Brake to master ratio 14.63
R33 GTST
Master Cylinder diam (mm) 23.8 444.88mm²
Front rotors (diam x thk) 296×30
Brake to master ratio 16.67
R32 GTR (Non V-Spec)
Front rotors (diam x thk) 296×32
R32 GTR V-Spec / R33 / 34 GTR with Brembos
Master Cylinder diam (mm) 26.9 568.32mm²
Front Caliper Piston(diam x qty) (44+3Cool×2 ... leading pistons smaller then trailing 5309.29mm²
Front rotors (diam x thk) 324×30
Rear Caliper Piston(diam x qty) 40×2 2513.27mm² ratio FR = 2.1125
Rear Rotors (diam x thk) 300×22
Brake to master ratio 13.76
- rat
- Real Name: Rat
Re: Nissan Skyline brake disc and caliper information
Ah,lekka bud, thanks !
Good info and Im busy with the Porsche stuff at the mo....
- rat
- Real Name: Rat
found this while looking for the difference between my R32 Rear Calipers and my R33 Brembos
