Project ANARCHY
Re: Project ANARCHY
So this weekend got a few things done motor is in just need to do the odds and ends around the motor and we good to go
Re: Project ANARCHY
Nice Jason, good luck on the start up!!
Re: Project ANARCHY
All hail J!!
Re: Project ANARCHY
Ok so first start up was successful motor started first swing once i decided to plug the ignitor in but could hear a miss and the car wasnt running 100% same as before the bearing knock and rebuild so checked the spark fueling ecu maf ect ect could not find what was causing the issue it seemed that cylinder number 4 was not firing properly after scratching my head for a week or so trying everything in the book i decided to do a compression test
So that was piston 4 lol so after seeing that i connected the compressor the the spark plug hole to find out where the leak was coming from turns out the exhaust valve was leaking quite badly engineering ftw so parked the car next morning friend and i pulled the head off only to find this
If you cant see it that middle valve is bent so both exhaust valvs were bent luckily i had spares lying around so we lapped new valves put the head on and after 12 hours of work fired the car up and she was running perfect Car has now done 800km and is a pleasure to drive replaced the rear bumper and had her detailed over the weekend and she is looking better than ever
Re: Project ANARCHY
Jussie you and Richard can polish n' ding stukkend huh!!
Cool stuff, glad it runs good. Well done!
Re: Project ANARCHY
lol no payed someone to polish it for me lol he took 9 hours to egt it to shine like thatDraco wrote:Jussie you and Richard can polish n' ding stukkend huh!!
Re: Project ANARCHY
Damn....he must be expensive, gotta pay me some good money to detail a car for 9 hours
- Real Name: Jacques Louwrens
Re: Project ANARCHY
Congratz!
S13 200sx CA18DET
S13 200sx CA18DET
Re: Project ANARCHY
Looking good! but the boot!
Re: Project ANARCHY
lol yes will sort that out lol
Re: Project ANARCHY
LOVE IT!
- 0.2 Bar Boost
- Real Name: robert
Re: Project ANARCHY
Dude your already so short you should be extending the hub lol.
Sent from my SM-G900H using Tapatalk
- Skippy
- 0.2 Bar Boost
- Real Name: Matthew
Re: Project ANARCHY
nice work Jason
Re: Project ANARCHY
Ok so long over due update will start with the white sx.
Aricon fixed
abs fixed
reverse lights fixed
interior light fixed
Have now had a total of 6 water leaks from pipes been so old but car is doing well have 8000km on the rebuilt motor and car is pulling like a train very happy with it as a daily
Aricon fixed
abs fixed
- Attachments
- 20151017_132019.jpg (6.8 MiB) Viewed 58729 times
- 20151112_170939.jpg (3.24 MiB) Viewed 58729 times
- 20151014_193055.jpg (5.27 MiB) Viewed 58729 times
- 20151006_180654.jpg (5.49 MiB) Viewed 58729 times
