Gary57 wrote:I heard the RB26 cam cover is the same as the CA18!!?? The motors are pretty much the same just with 2 extra cylinders, well so I have read.
LOL - never thought of that!
the aesthetic design is different, but maybe the mounting points and dimensions are the same!
not a bad conclusion watson!
I got an extra cover that I want to introduce to an angle grinder
An extra clear one or STD?? If it is STD rather keep it and take it to a company that does injection moulding and they can make them clear for you. If we get enough guys keen then it will be cheaper.
Vlade wrote:Don't think it would fit hey... I think the guys on SXOC already tried it... I got an extra cover that I want to introduce to an angle grinder
hey vlade, do you have the other two cam covers as well???
cos then i will take them to be powder coated gloss black, and i will give you my shiny ones. a straight swop?
or how much do you want for them??
Sure no problem in doing that... I hope they fit your breather piping config though, mine on my engine is a combo from FWD engine and RWD engine.
Geez guys, are you serious? Clear cam covers? Have you seen what the insides of your cam covers look like? Unless you've done an engine rebuild recently, it will hardly be worth looking at
even better!!! less kak to worry about!
and toby - the inside of mine looks like very finely shredded cam belt shavings. is that bad???
