RB26 cams fit the RB25 NEO ??
Posted: Sat Oct 15, 2011 8:39 pm
by BigKriss
Just got given a pair of Tomei RB26 cams, I am getting conflicting info regarding this, does someone KNOWLEDGEABLE now if it`s possible ??
Otherwise its pull the old motor apart to check...
Re: RB26 cams fit the RB25 NEO ??
Posted: Sat Oct 15, 2011 10:15 pm
by Tobie
What spec are the Tomei cams, Pon or Pro?
Posted: Sat Oct 15, 2011 10:53 pm
RB26 has solid lifters and RB25 has hydrollic
Posted: Sat Oct 15, 2011 11:06 pm
by Tobie
The Neo has solid lifters.
Posted: Sun Oct 16, 2011 1:26 am
Is there a part number? check that on the tomei website
Posted: Sun Oct 16, 2011 9:16 am
by Tobie
The reason I asked for the cam specs is if it is high lift Procams you will need new shims, lifters, springs and retainers, so there would not be a problem fitting it to the NEO head.
The loss of VCT would be a bummer though.
Not sure if the direct replacement Poncams would work though.
Posted: Sun Oct 16, 2011 11:04 am
by viper cape
the cams do not fit the neo as per their website
Posted: Sun Oct 16, 2011 11:08 pm
by aep886
RB25 block + RB26 head = awesome~!!! and they fit together like magic
Posted: Mon Oct 17, 2011 5:42 am
by BigKriss
Getting the cams this week. Tobie, will let you know. I`m leaning towards going full RB26 here. But then we go moggy, after the R33 and the Stegia I need to.
Posted: Mon Oct 17, 2011 7:50 am
by Tobie
Series 1 RB25 running FULL RB26 valve train. this car runs low tens and the mods was done by Steve at No Sweat Racing.
