Ca18 can't idle
Posted: Sat Oct 15, 2011 12:32 pm
by future sx owner
Hi there
I have recently install a bigger turbo n fmic on my car. now its start but wen i take my foot off the gas its die. What do you guys cause the problem?
I'm still running stoke ecu and fuel pump. Do u guys a fuel pump upgrade will sort this problem?
Re: Ca18 can't idle
Posted: Sat Oct 15, 2011 12:35 pm
by aep886
it has something to do with your fuel system, fuel disterbuter maybe~ it happen the same to my sentra!
Re: Ca18 can't idle
Posted: Sat Oct 15, 2011 9:04 pm
by poizen
Air leak
Re: Ca18 can't idle
Posted: Sun Oct 16, 2011 6:57 pm
by future sx owner
air leak as in boost leak? i check all the boost pipe n everything is tight but it still can't idle!
Re: Ca18 can't idle
Posted: Mon Oct 17, 2011 7:51 am
Did you keep your standard boost pipes...?
Re: Ca18 can't idle
Posted: Mon Oct 17, 2011 7:55 am
Is your afm plugged in?
Re: Ca18 can't idle
Posted: Mon Oct 17, 2011 3:26 pm
by future sx owner
No not using standard pipe. Using 60mm pipe now. i did plug in the maf
but still stalling. will try to adjust the bov again to see if its help.
Re: Ca18 can't idle
Posted: Mon Oct 17, 2011 3:28 pm
The pipe that goes from the boost to the idle control?
Re: Ca18 can't idle
Posted: Mon Oct 17, 2011 3:29 pm
by future sx owner
Oh ya i did try to start the car with out the maf but cant start. is that normal?
Re: Ca18 can't idle
Posted: Mon Oct 17, 2011 3:31 pm
future sx owner wrote:No not using standard pipe. Using 60mm pipe now. i did plug in the maf
is it open when you keep it running?
Re: Ca18 can't idle
Posted: Mon Oct 17, 2011 3:38 pm
by future sx owner
Yes those r all still in place. didnt take any of those off wen i was working on the car.
I did how ever replsce some of the small metal vacuume pipe in to soft rubber 1. would thet affect anything?
Re: Ca18 can't idle
Posted: Mon Oct 17, 2011 3:47 pm
by future sx owner
[quote][/quote]
Nno sure if the bov is open wen im ideling. how do i chech?
