Please help! Water leak
Posted: Sun Aug 14, 2011 4:48 pm
by k.y.l.e.
Hey guys i noticed some water dripping at the bottom of my car its a s13 200sx with s14 sr20det motor and gearbox i poped the hood and could not find any thing so jacked up the car had a look under the car and saw something strange if you laying straight under the car with your back to the ground and you look at the oil filter just left from the filter the water seems to be coming out there? Can any body direct me in what to do
Re: Please help! Water leak
Posted: Sun Aug 14, 2011 4:55 pm
by NIZAN-R
must be leaking heater hose under the intake
Posted: Sun Aug 14, 2011 5:01 pm
by k.y.l.e.
It does not seem to be from a pipe thow its were theres bolts
Posted: Sun Aug 14, 2011 5:11 pm
by Dumani
This is just a stab in the dark but maybe one of the bolts is missing a washer or its worn.
Posted: Sun Aug 14, 2011 7:27 pm
by k.y.l.e.
Thanks man any body else with input
Posted: Sun Aug 14, 2011 7:31 pm
by poizen
Hey dude if it by the oil filter it may be the stock oil cooler kit it has 2 water pipes running to it take a pick and post
But remember just cos it looks like its from the bolt doesn't mean that it is water is one of the hardest things to trace where a leak starts just tighten the clamps and look for small tear
Posted: Sun Aug 14, 2011 8:46 pm
by k.y.l.e.
K kwl will try and post a pic 2moro reason why i think its for sure there is that there a build up of brown rust water paste were the water droplets form from, started leaking after i gave it a good service when i put radiator flush in so i think the rust paste prevented it from leaking and the radiator flush cleand the rust away in turn leaving a gap for water to seap threw
Posted: Sun Aug 14, 2011 9:08 pm
by mario_200sx
Kyle. if you want to, come past my place tomorrow if you can. I can have a look for you. Gimme a call. 0727four6seven415
Posted: Sun Aug 14, 2011 10:02 pm
sounds like the oil cooler
Posted: Mon Aug 15, 2011 8:06 am
by k.y.l.e.
So does the water chanel pass were the oil is ofcoarse not with the oil but were the oil circulates to help it keep kwl, please guys be patient with me as i am getting to know my car still thanks
Posted: Mon Aug 15, 2011 10:05 am
by poizen
thats correct yes
Posted: Mon Aug 15, 2011 10:11 am
by k.y.l.e.
Oh ok kwl that makes sence sounds like its going to pricey to fix
Posted: Mon Aug 15, 2011 10:12 am
by poizen
nope its prob just a small tear or loose pipe max 100 id say
Posted: Mon Aug 15, 2011 10:19 am
by k.y.l.e.
Now thats good news i hope its that thow
Posted: Fri Aug 26, 2011 4:18 pm
by k.y.l.e.
Hey poizen you were spot on it was the water pipe going to the oil cooler, any body have a spare pipe like this its in a u shape
