Advice on AFM
Posted: Mon Jul 04, 2011 5:19 pm
by Dumani
I need an afm for my sx but if i cannot get one what other options do I have?
Re: Advice on AFM
Posted: Mon Jul 04, 2011 6:58 pm
by aep886
Z32 and Q45
Re: Advice on AFM
Posted: Tue Jul 05, 2011 8:13 am
by Enzio
Are you sure your MAF is broken? Have you now checked the error codes on the ECU? What codes did you get?
Since you still have stock management a Z32 or Q45 MAF will definitely NOT work.
If you want to get rid of the MAF completely, your only option is to change management to something that works with a MAP sensor.
Re: Advice on AFM
Posted: Tue Jul 05, 2011 1:45 pm
by POWDER
Dumani, if it's a CA18DET you running, I have one that you are more than welcome to test with boet.....
PM me
Re: Advice on AFM
Posted: Tue Jul 05, 2011 2:12 pm
by Dumani
Yeah I have a ca18det. Reason I'm looking for an afm is that my car is stalling and I've recently changed the ignition coils and the car worked fine for a while and now the problem has made a return. When i rev though the engine works but soon as i come to a stop the engine cuts out.
Re: Advice on AFM
Posted: Tue Jul 05, 2011 2:15 pm
by Dumani
And I'll happily take you up on that kind offer Powder cos I'd hate to buy an afm then find out its not needed. Where can I get hold of you
Re: Advice on AFM
Posted: Tue Jul 05, 2011 2:26 pm
by POWDER
PM sent boet.... Give me a call
Re: Advice on AFM
Posted: Tue Jul 05, 2011 3:52 pm
by Dumani
I checked the ecu for error codes and it gave me in mode 3 code 55 which ,according to the service manual, means there's no faults being picked up.
Re: Advice on AFM
Posted: Tue Jul 05, 2011 3:59 pm
by Dumani
And the little cartoon on the service manual was all smiles and the manual made it sound so EASY to get that damn ecu out of its lil' compartment. Getting that damned thing out was the hardest thing I've ever done...until I had to put it back in. Almost left it on the floor. Sorry for rambling on guys, just very ticked off
Re: Advice on AFM
Posted: Tue Jul 05, 2011 4:27 pm
by POWDER
Well if thats the case then the MAF should be fine..... Might just be a little dirty if it is that....
Might be a vacume line givving issues or the cas that is out by a bit...... My bet is vacume leak though with what your explaining.....
but will check a few things out when I see you
Re: Advice on AFM
Posted: Tue Jul 05, 2011 4:32 pm
by Enzio
Finally. No error codes, this is a good start.
Now clean the MAF
Check for boost leaks
Check vacuum lines as POWDER says
Pull plugs and check their condition
Re: Advice on AFM
Posted: Tue Jul 05, 2011 6:59 pm
by POWDER
O hell yes, enzio is right, a CA or a SR is always fussy with plugs.... ALWAYS..... Hotstuffs SX didn't want to start, problem? Plugs..... Mine did same thing..... Good point Enzio
Re: Advice on AFM
Posted: Tue Jul 05, 2011 7:34 pm
by Dumani
I'm gonna take a stab in the dark here and guess that the ''plugs'' you guys are reffering to are the spark plugs? And if thats the case they were changed recently wen i took the car for a service
Re: Advice on AFM
Posted: Tue Jul 05, 2011 7:39 pm
by Dumani
And Powder bro the car can hardly move so I dont know how I'd get her to your place unless if I set off now then I'd maybe get to your place by sunset tomorrow :|
Re: Advice on AFM
Posted: Wed Jul 06, 2011 6:38 am
by mario_200sx
Check plugs again, might have one faulty plug. Also make sure that the gap on the plug is spot on.These cars are very sensitive to plugs.
Dont get frustrated so easily, take it one step at a time. You will get there.
Buy some carb cleaner clean the the MAF,
if it doesnt work -
Get new plugs and GAP accordingly,
if it doesnt work -
Check all of the boost and Vacuum pipes.
Get back to us then.....
