Advice
Posted: Tue Jun 28, 2011 9:10 am
I am sitting with some some headaches....this is the problem.
I am going to buy a turbo and am planning to boost around 1.5 bar, now I am sure most guys know that high octane fuel(racing fuel) is not so freely availible as it use to be, plus, I am planning to drive the car on the road on weekends and what not.
I have 3 obsions, run 50/50 methanol and 95 fuel, run water/meth with 95 fuel or get 105 or 120 octane fuel.
All 3 of these has it's pro's and cons....
option one: 50/50 methanol and 95 mix, that means regualar oil changes, fuel filters and so on might be affected by the meth, although it will be mixed with 95 that will alter it's destructive "force".
option 2: water/meth and 95 fuel, will a healthy amount of water/meth with 95 be enough to sustain 1.5 bar boost, this means an extra +- 4k for the kit and more time wasted with installation and so forth, also assuming I will have a big enough jet to sustain the boost level.
option 3: buy as much 105 or 120 octane fuel as I can get my hand on, problems, storing the fuel is dangerous, storing it for to long might also affect the octane level(this is what I read) and will it support 1.5 boost?
What say you?
Re: Advice
Posted: Tue Jun 28, 2011 9:33 am
W/M once off cost for the kit and a 20L drum will last you a year and costs R300
Re: Advice
Posted: Tue Jun 28, 2011 9:34 am
by Adrian
No expert here but what about the octane boosters you can buy. Seen them with a 10 octane +....
Re: Advice
Posted: Tue Jun 28, 2011 9:52 am
Adrian wrote:No expert here but what about the octane boosters you can buy. Seen them with a 10 octane +....
I don't trust those boosters....
Re: Advice
Posted: Tue Jun 28, 2011 10:09 am
by djtreble
Stay away from octane boosters.
I am looking at running racing fuel or water/meth, still to decide which is more reliable (water meth injection reliability or long storage of racing fuel) but yes if your car is mapped right, 102 is more than enough.
Guys in the UK run that boost on 97
Re: Advice
Posted: Tue Jun 28, 2011 10:21 am
The thing is with water/meth, it boosts your octane to around 116 ron...which is fine....but then you need to inject the right amount....to little...and it won't do the job...too much and you might quinch...
I never had the problem but a friend had the problem of a blocked nozzle every now and then...thats also something that makes me wary...
Re: Advice
Posted: Tue Jun 28, 2011 10:26 am
On top of that....I want all my stuff in the boot...and I want a big tank, don't want to refill w/m after every drive...
Re: Advice
Posted: Tue Jun 28, 2011 11:04 am
by POWDER
Derek, I would go with w/m , just arrange a jet towards your expected power expectations and adjust meth content towards that 50% meth being most you run to get max power safe.... My 2c .....
You can also set the w/m to only kick in at a sertain boost level so if you not gonna be boosting full all the time, you wont waste.... you should be able to run on one 2 liter tank for about 2 to 3 months if you dont drive like you do
Re: Advice
Posted: Tue Jun 28, 2011 11:12 am
by 300sx
you do know that you can run 100% water right? it is the water that provides the anti detonation properties, the meth provides a little more power.. i run my aquamist system on 100% distilled water..
Re: Advice
Posted: Tue Jun 28, 2011 11:19 am
Hey bud, thanks for the info...I always mix my w/m 50/50...that does not mean 1 liter meth, 1 liter water...they weight different...different dencity, so you need to work it out.
As for the nozzle, they use to supply 3 nozzles according to your HP needs, these days seems they only give one nozzle,.
As for the rest...I will go with progressive electronic unit, not maunual, I had the manual and although it worked fine, from a certain setting it sprays the same amount all the way, that makes tuning a bit harder.
I had a 1.5 liter tank in the boot, I emptied it in a week.....good luck on letting 2l last you 2 months...
![200SX_001_icon16 [smilie=200sx_001_icon16.gif]](./images/smilies/200SX_001_icon16.gif)
Re: Advice
Posted: Tue Jun 28, 2011 11:20 am
300sx wrote:you do know that you can run 100% water right? it is the water that provides the anti detonation properties, the meth provides a little more power.. i run my aquamist system on 100% distilled water..
Yes I do thanks Nico....but you know me...I'm after everything...power and and and...so just water is no good for me...
Re: Advice
Posted: Tue Jun 28, 2011 12:40 pm
by aep886
i have run GT3037S-pro with 98 boosting 1,9bar with no problem...
Re: Advice
Posted: Tue Jun 28, 2011 1:01 pm
by mario_200sx
Hey Draco, dont waste your time with stupid fuel mixtures and so on.
Get the water/meth system, just make sure you are using distilled water.....if you dont, THEN the nozzles clog. Otherwise you wont be sitting with clogging issues.
And cleaning of the nozzle should be a routine maintanace on your car anyway. Every 6 months take it out and give it a clean.
Water/meth works and you dont need anything else. Its also the cheaper route in the long run.
Re: Advice
Posted: Tue Jun 28, 2011 1:09 pm
mario_200sx wrote:Hey Draco, dont waste your time with stupid fuel mixtures and so on.
Thanks Mario, funny thing is,Freddy use to use destilled water and his nozzle glogged regularly....I used normal tap water and mine never blocked...and I never cleaned it either....I was damn lucky I suppose...
Re: Advice
Posted: Tue Jun 28, 2011 1:33 pm
by mario_200sx
Draco wrote:mario_200sx wrote:Hey Draco, dont waste your time with stupid fuel mixtures and so on.
I guess you where!
If his clogged on a regular basis I think there must have been a problem somewhere else......
