Dash clock resets itself everytime you open a door???
Posted: Sat Jun 11, 2011 7:26 pm
by Yakuza
Hey people..
Got this nasty problem,car has a alarm system connected to everything that can be opened. So the issue is that once you open a door or the hood the clock resets itself on 1;00..
So the first thing I think its got something to do with either the alarm or ignition..Did any1 else have this problem?? WHats the cure??
Posted: Sat Jun 11, 2011 7:47 pm
by aep886
your wires not connected probably... coz it cut of the power completely every time... get a proper auto electriction to sort it out... it happen the same to my friends car
Posted: Sat Jun 11, 2011 8:52 pm
by POWDER
Dude, since it happening with hood and doors, I would be inclined to thing that your door indicator switches have a short somhow with the clock power, both door switches and lock power run through the harness behind the cluster, I would check that if you clip the door switch indicator lines from the harnes, does it still do the same thing? You should be able to release the indicator pins from the harness plugs withought damaging the wires them selves....
If u need a wiring diagram for the pinout of the harness, u can check in my project build, I have drawn one up and posted in there
Hope this helps..... U might just need to replace a wire and sorted....
Posted: Mon Jun 13, 2011 9:31 pm
by araf69
Had the same problem - does the interior light work as well. I took mine to an electrician and he just a changed a fuse in the fusebox. The interior light fuse. Try also switching the interior light on and off. My radio also didn't work because it was connected to the ignition
