Car Bogging between 2k - 3.5k rpm
Posted: Tue Mar 08, 2011 2:44 pm
by Fastlane
Hi guys,
Any helpful feedback will be appreciated.
My SX (CA18det) bogs between about 2000 to 3500 rpm when I try to floor it, then moves when it boosts.
It also feels sluggish when driving out of boost - no power.
I have fitted a ''300lph 6 bar'' no name brand fuel pump in December but the problem persists.
FP Guage is at 2.8 bar at idle and drops to 2.5 bar under load. Is this normal?
I disconnected the FPR and it makes no difference?!? Still behaves the same.
Moved CAS a bit (advanced) and it seems to be a bit better (only just).
Motor was completely rebuilt about 950km ago. Mechanic omitted Knock Sensor. Is this okay???
Help Please!!!
Posted: Tue Mar 08, 2011 3:03 pm
Fuel related. You should have 3,6 bar on idle and it should go up when you rev the car, not down.
Re: Car Bogging between 2k - 3.5k rpm
Posted: Tue Mar 08, 2011 3:10 pm
by Daniel
Fastlane wrote:Hi guys,
Help Please!!!
What do you mean by this?
Posted: Tue Mar 08, 2011 3:12 pm
Sorry 2,6bar on idle and the go up.
CA Bogging
Posted: Tue Mar 08, 2011 3:42 pm
by Fastlane
Thanks for the replies guys.
@ Daniel : The Mechie said that he did not fit the Knock sensor because it did not do any good when the motor blew the first time around. I don't know if I agree with his reasoning. I do have the knock sensor. Should I fit it?
@Charlvdw : What should the Fuel pressure go up to at W.O.T.?
I have just ordered a Walbro Fuel Pump from Duane (Team Obsession).
Any theories on the FPR???
Posted: Tue Mar 08, 2011 4:20 pm
by Grobblere
Personally i think its your knock sensor. Without it the ecu goes into limp mode to protect against detonation, your mechanic's theory really sucks. :D
These cars might be old but the ecu's are not 2 far behind...its not a golf esse :-)
If your pressure drops then your fuel pump cannot supply as it should. Your Fpr shouldn't give problems easily and also your description does not really fit a faulty fpr.
Im going to remove my knock sensor tomorrow and check if i can find an alternative.....
:D
Posted: Tue Mar 08, 2011 4:50 pm
by 300sx
lol, i cant believe some people.. how about we remove your afm too, i mean its only a restriction...
Posted: Tue Mar 08, 2011 5:00 pm
by Grobblere
remove your car wheels, they just create rolling resistance :twisted: :roll: :wink: haha
Posted: Tue Mar 08, 2011 5:10 pm
by Daniel
Yeah if there's no knock sensor it will run pretty crap.
You can also bypass the sensor using a 470k resistor to ground :wink:
Bogging
Posted: Wed Mar 09, 2011 10:17 am
by Fastlane
Sheesh :roll: Thanks guys, that really helps. Ha Ha Ha, let's just remove the engine etc. as it just adds weight to the car, ha ha ha.
It is already obvious that I don't agree with the Mechie's decision about omitting the knock sensor, but will the lack of the knock sensor cause the symptoms I've previously described.
Thanks for your positive contributions Daniel. Much appreciated.
Anything further with regard to the behaviour of the car when I removed the vacuum pipe from the FPR. (I'm also not sure, but it seems that the said vacuum pipe connects at the other end to a source that's located just below/on the ignition module.)
Posted: Wed Mar 09, 2011 11:46 am
by Lindt
the fpr on the s13 is connected to a hot start solenoid, make sure that thing is working as it's cuts the vacuum line to the fpr
Bogging
Posted: Wed Mar 09, 2011 12:10 pm
by Fastlane
''Hot start solenoid''???, sorry I'm not familiar with this. where or how can I check this? Is it located near or on the ignition module?
Sorted!!!
Posted: Tue Mar 15, 2011 1:04 pm
by Fastlane
Okay, installed a Walbro 255lph Fuel Pump on Friday evening, and the car feels so much better. Just need to check and adjust timing and base idle, maybe set CO's.
