Will Autolite XP3923, Iridium plugs work in a CA18DET motor?
Wanted or for sale
Locked
Just_Cruzn
Real Name: JP
Post by Just_Cruzn »
Hi guys and gals,
Hope all your SX's are treating you well!
Mines due for a oil change, diff and engine and i would also like to change the sparks plugs. I want Iridium sparks plugs, maybe Ngk's?
Can anyone supply me with Iridium spark plugs or know where i can get a set?
Your quick response will be appreciated as i'm planning on doing the oil change this week.
PS. I'm in Cape Town
Lindt
Post by Lindt »
I'll never use platinum plugs in a turbo car, either normal electrode or iridiums
Just_Cruzn
Real Name: JP
Lindt wrote:I'll never use platinum plugs in a turbo car, either normal electrode or iridiums
thanks for the reply Lindt
I was just doing some research now, seems like iridium ngk's are the best of both worlds (meaning they last longer because they are harder and turbo cars seem to like them)
The std plugs for the VG is platinum. I bought a set , will see how they work.
Just_Cruzn
Real Name: JP
where did you manage to get a set of platinum plugs?
do you have to import iridium plugs for a ca18det motor?
i'm going to phone around today and see what i can find a set.
In don't even bother phoning around ,i just import. I can get you iridiums for the ca, think it came to R550 a set last time.
Just_Cruzn
Real Name: JP
Charlvdw wrote:
Just_Cruzn wrote:
Charlvdw wrote: The std plugs for the VG is platinum. I bought a set , will see how they work.
Hi Charlvdw,
i managed to find Autolite XP3923, Irdium plugs, would they work in my nissan? R80 a plug.
You help will be greatly appreciated
R80 a plug is not bad for iridiums ,but i dont know this make.
I like to stick to something i know like NGK or Bosch.
Just make sure that your gap is set in the ,7mm range.
Just_Cruzn
Real Name: JP
The guy can get them for me this friday.
But i'm wondering if they will fit and work properly.
Here is the URL http://cgi.ebay.com/ebaymotors/ws/eBayI ... vi-content
And no i'm not buying them from Ebay, i just got the specs off there.
# Electrode Core Material
Copper
# Electrode Tip Material
Iridium
# Ground Strap Quantity
One
# Insulator Type
Projected
# Quantity
Sold individually.
# Resistor
Yes
# Shorty Spark Plug
No
# Spark Plug Reach
0.750 in.
# Spark Plug Seat Style
Gasket
# Spark Plug Thread Size
14mm
# Wrench Diameter
5/8 in.
Do you think it will fit, i'm currently using NGK BCPR6ES-11
angelo
Post by angelo »
Stick with the NGK,s copper
NGK BCPR6ES -11
NGK BCPR6ES -8
Just make sure the gap is ,7mm -,8mm
If you realy want iridiums check the rezlo store, I think they about R120 each.
But like I say the ngk copper will do the job
Locked
