wanted 200sx rear wheel bearings
Wanted or for sale
Locked
nosh
Newbie
Post by nosh »
does anyone have or could tell me were i could purchase rear wheel bearings for my 1992 200sx
ads
Real Name: Adam
Bearing
Post by ads »
Bearing man, Nissan, fag bearings, timken,
nosh
Newbie
Post by nosh »
only nissan has them and they are R2000 a side thats 10% of the value of my car :shock:
Ebay!
ads
Real Name: Adam
B
Post by ads »
Did you go to these places with the bearing in hand?
Re: B
ads wrote:Did you go to these places with the bearing in hand?
You don't get them loose you have to buy the whole hub and locally only Nissan sells it. Trust me Ive done the exercise.
Its very difficult to match them, but if you go with it, they will match it.
If its for a S13, lemme know the code. Been looking for a set for a long time.
Drillergy wrote:Its very difficult to match them, but if you go with it, they will match it.
What are they gonna match Darrel? You cant take the bearing out like the front once, its part of hub.
Skylinefreak
Post by Skylinefreak »
Or you can buy a Ichiba 5 stud hub kit for front and rear for R5600 from Rezlo.
Skylinefreak wrote:Or you can buy a Ichiba 5 stud hub kit for front and rear for R5600 from Rezlo.
+1
Then you need just to get brake disc's and mags.
Skylinefreak
Discs can be drilled to 5 stud, wheels will cost a bit though! Just making sure all the options are on the table :)
Skylinefreak wrote:Discs can be drilled to 5 stud, wheels will cost a bit though! Just making sure all the options are on the table :)
It would be the better option to just go 5 lug and get it over with but it works out a sh!tload. :)
Yes it does.
nosh
Newbie
Post by nosh »
you can pop the bearing out by using a vice. my bearings were not damaged so i bought some skf bearing grease and its fine now.
Locked
