S13 suspension kit
Posted: Sun Nov 14, 2010 1:46 am
by denoSX
Im thinking of getting this godspeed kit...Should work out to about R5000
what you guys think? Anyone else perhaps interested, gonna contact seller monday or tuesday!
Posted: Sun Nov 14, 2010 6:35 pm
by poizen
ive thought about these kits alot but i went coilover route instead and i got it set up perfect for road and track with out it so i dont think you need it unless you want crazy camber
Posted: Sun Nov 14, 2010 10:16 pm
by denoSX
Would this not compliment Coilovers?
Posted: Mon Nov 15, 2010 7:15 am
by poizen
yes it will complement it
but in my opinion its a nice to have not a need to have
unless you going full drift and need that rear CAMBER
but like i say my car handels great just with coilovers street and track
but still somthing ive always wanted
Posted: Mon Nov 15, 2010 7:50 am
by n1smo200sx
the biggest suspension mod is swaybars-nothing compares.
Posted: Mon Nov 15, 2010 8:51 am
by 300sx
+1000
Posted: Mon Nov 15, 2010 8:56 am
by poizen
yes sway bars are a good must but the rest is not really needed
Posted: Mon Nov 15, 2010 10:23 am
by Daniel
I believe the other way around. If you have a solid coilover setup sway bars will make little difference as body roll will be kept in check with the coilovers.
And those adjustable arms will be necessary with coilovers (depending on ride height) as the suspension geometry goes out the lower you go.
Posted: Mon Nov 15, 2010 1:15 pm
by n1smo200sx
swaybars
Posted: Mon Nov 15, 2010 2:00 pm
by DriftZ
swaybars are pretty much the cheaper version of coilovers.
either run sway bars.. or run coils.. but you dont really 'need' both.
problem comes in when you wanna start fiddling... ie .. lowering which you can do easily enough with coils... though what people forget about coils is.. each time you fiddle with either your height adjustment or camber or wtvr.. you will need to have your alignment redone. When i first had my coils and suspension i was playing all the time.. and was having to have my alignment done atleast once a week.. @ R230 per alignment session.. became costly. but i fiddled to a point where i like its settings and now i only go for alignment once every 2 months. that said .. after driving in Poizns car .. his suspension feels far grippier and stable than mine :( .. not that mine is meant to be stable :)
...The complete suspension kits are excellent.. but be carefull you dont end up setting it wrong and having to drive a snappy, bumpy .. mishandling car.
... personally id suggest keeping the suspension as simple as possible, the smallest changes can make the biggest improvements.
Posted: Mon Nov 15, 2010 2:22 pm
by n1smo200sx
Got tein Super streets-nice
Got poly bushes -nicer
got -nismo brace-oh well
Got swaybars- OMG thats grip
All those things are nice to have when the car slammed.
Longer ball joints to bring the roll centre back to original after the car is lowered will make more difference on your cornering speed than any suspension mod anyways(my next purchase)
Posted: Mon Nov 15, 2010 5:21 pm
by denoSX
Thanks for all the advice...
So would you guys say - Sway bars, strut braces and poly bush kit would compliment Coilovers well...
Posted: Mon Nov 15, 2010 5:33 pm
by 300sx
hehe, im no suspension guru, but i fail to see how you guys are even comparing coilovers with swaybars.. they do 2 differant things!!
swaybars control the wheels movement in relation to each other, thus having a huge effect on under or oversteer, depending on their setup..
shocks/springs or coilovers control the movement of the wheel its attached to, thus controlling ride height , rebound ect..
Posted: Mon Nov 15, 2010 6:35 pm
by DriftZ
300sx wrote:hehe, im no suspension guru, but i fail to see how you guys are even comparing coilovers with swaybars.. they do 2 differant things!!
By no means would i have sway bars over coilovers.. coz coilovers do heaps more... but they do affect some core suspension outputs similarily..... but mostly in the corners
coilovers...
stiffen suspension
less suspension travel
balance the car
Sway bars...
balance load between wheels giving a stiffer suspension 'feel'
give less car body roll .. ie the feel of less suspension travel
balance the car
Posted: Tue Nov 16, 2010 10:00 am
by 300sx
to re-iterate.. +1000
