more RB talk.
Posted: Wed Nov 10, 2010 10:09 pm
Hi guy's...
Trust everyone is well.
I am in need of assistance with a issue regarding my RB25DET fitted to my S13.
The car goes exceptionally well, there is however one problem.
I have a Mashimoto allimunuim radiator fitted with two 10inch electronic radiator fans.
The setup works 100% for normal driving, dyno tuning, traffic and also for balls to the wall open road low flying.
However I found that the car heats up quickly and doesn't keep a constant tempreture when playing around after hours in Brakenfell Hypermarket's parking lots, going side ways and shredding rubber.
The car is fitted with the stock frond bumper, I believe this is restricting the airflow quit a bit.
Any suggestions?
I am working on a pressurized water spray system that drenches both inter-cooler and radiator with a water/nitrogen mixture.
Similar to what is fitted to a stock WRX scooby.
I am using a 9kg fire extinguisher body, charged with 8l of h20 and pressurized with 270psi of nitrogen (standard H20 extinguisher).
The system is mounted in-car and the standard noble has been replaced with a 12volt solenoid (operated from a push button on the dash), piped into hoses that feed the mixture to a spray bar fitted to radiator and inter-cooler.
Also were can I take my car to have a full rolcage fitted and made up to MSA standards?
How many RB guys are there in CPT, any one interested in a RB S13/S14 get together?
Kind regards
Richard
Any suggestions?
Kind regards
Richard
