Wanted: conversion to make my speedo work -SX RB25
Posted: Tue Sep 28, 2010 9:43 pm
by Raymond R31
I need a new plug or adapter to make my std speedo work with RB motor and gearbox. Please pm my if you can assist.
Posted: Wed Sep 29, 2010 2:37 pm
by aep886
convert the R33 speedo in to your SX
Posted: Wed Sep 29, 2010 2:48 pm
by Raymond R31
aep886 wrote:convert the R33 speedo in to your SX
where do I get one? Sounds like a plan.
Posted: Wed Sep 29, 2010 2:53 pm
by nirvash
im sure if you use your speed sensor from your ca18det gearbox it will work fine
somone correct me if i'm wrong, but that should work i think
Posted: Wed Sep 29, 2010 3:05 pm
It should even work from the rb pickup its just not going to be accurate necessarily. I know of two deferent pickups just for the ca box so you'll just have to find the right one.
Posted: Wed Sep 29, 2010 9:31 pm
by 200sxrb25
I use my ca 18det sensor on the rb box and work fine on low speed, if you go to 180+ you will see a it is out.
Posted: Wed Sep 29, 2010 9:39 pm
by Raymond R31
I will give that a go. Just want some idea how fast I am going. i can always calibrate it with gps.
