Overheating issue - calling all fundi's !!
Posted: Tue Aug 17, 2010 6:10 am
by Andrew.200SX
Before I start looking for the cause , maybe someone has an answer for me..... Driving this morning , not boosting , just cruising on the N1 at around 100 km'h ,and the car's heat guage suddenly went North, redline. Stopped at a garage , water levels fine , electric fan working fine , drove off nursing the car just to get to the workshop (my office) suddenly the top radiator hose burst from the heat I presume
and then the heat guage dropped instantly to normal and I could drive to work , obviously after a couple of kilos the heat guage started to climb , due to the lack of water. Thermostat maybe ? Why would the car cool down after blowing a hose ?!?
Posted: Tue Aug 17, 2010 7:34 am
Most propably thermostat but it could be meny other things too......the guege will drop because all the water is out....
Posted: Tue Aug 17, 2010 7:38 am
by Andrew.200SX
yeah..makes sense. I am going to completely remove the thermostat, if there is one in to begin with and then let her run and see what happens. There is no water in the oil , but that doesn't rule out a blown head gasket.
Posted: Tue Aug 17, 2010 7:43 am
Taking out the thermo will still make it overheat after a while....the water goes through the radiator too fast....does not have time to cool down....
Posted: Tue Aug 17, 2010 7:58 am
by Andrew.200SX
I just removed the thermostat and tested it, it is seized solid. I will go and buy another 1 , as I have to go and buy a new hose anyway.
Thank God for my Voyager... Mr Reliable , 202000 km's on the clock and not a day's trouble.....and thanks to prolong again , and as usual, for allowing me to drive the "BEAST" 28 kilos to work this morning without water !! Prolong has saved me a couple of engines over the years.
Posted: Thu Aug 19, 2010 8:51 pm
by SilviaS13
lucky lucky
Posted: Fri Aug 20, 2010 8:04 am
by Andrew.200SX
Yip pretty lucky. I bought another thermostat , which looked pretty much the same and was listed for the car according to the spares guys , I still can't really see any difference , but when I put it in , the housing cracked. Pratley and no thermostat and I am running fine , but I don't like the fact that the car is running a lot cooler now. I supose I will have to get 1 from the Agents.....R325. EISH !!
Posted: Wed Aug 25, 2010 9:16 am
by Andrew.200SX
Turns out that the image in the Echlin thermostat book for the SR20 is exactly like my thermostat , but the thermostat in the corresponding boxes are not.
Trying to figure out why.
Posted: Tue Sep 07, 2010 8:17 pm
by Ero_sennin
any news on this?
Posted: Tue Sep 07, 2010 8:34 pm
by Andrew.200SX
I bought a complete thermostat housing with the thermostat from a guy on the Nissanowners club , second hand , but in good condition.
Posted: Tue Sep 07, 2010 10:33 pm
by Ero_sennin
damnnabit. Cause I suspect I need a new thermostat. still need to test tho, but just need to find one if tis the case
Posted: Wed Sep 08, 2010 8:01 am
by Andrew.200SX
You can buy the Motorad 1 from Masterparts. R 95
Posted: Wed Sep 08, 2010 8:05 am
Is she fine now?
Posted: Wed Sep 08, 2010 8:12 am
by Andrew.200SX
Perfect thanks , except that I still need to get her to Dynotech for a decent dyno tune. Still a bit of occasional spluttering at 1 bar. They say that they will try and tune the XMS-L management system , I hope they can , if I can ever get the car there !
