Kaihatsu Factory S14 Silvia
Posted: Tue Jul 13, 2010 10:53 am
So after chopping and changing cars, I think I have found the one I am going to build as I'm hooked on drifting and hope to compete in the future....it's the SA demo car for my company when I move back
First drifter I had was this:
In the end it was stage 2 CA18DET with minimal drift mods....even had open diff.
Then the big ends were knocking, so I pulled the engine out with the intention of rebuilding. After weighing up costs and finding my next car, I decided to break it.
I then bought this:
350bhp CA powered monster. Had alot of work done to it power wise and suspension/cage/stripped/etc/etc.
Then I got made redundant and started my own business. Due to finances I had to sell her. No one wanted to buy it as a whiole so I broke her too and made a fair bit of cash.
After things started to get better money wise I bought this 325 as a cheap drifter:
I did a bit of work on this including suspension, welded diff, fixed the many issues it had. After it's first drift day I wasn't entirely happy with the power and the huge difference in the drifting "feel/style" compared to a 200sx so I hunted around for one that I could work on and found my new car.
So here she is:
Spec isn't anything great....but is a perfect base for building a proper drifter.
Spec:
Silvia 1996
86000KM (54k miles!)
came into country 1 year ago
Real final connection bodykit
Shocks and springs (amazingly stiff and low)
cat back 2.75in exhaust
tight viscous diff
reclining bucket seat
Navan spoiler
18" Profound alloys with 25mm spacers all around.
The one back wheel is buckled so is to be repaired. And one side the wheels are primer and the other side they are chrome :wack:
I will be painting these white.
So far I have fitted a walbro:
A sparco steering wheel:
DW internal drive wheel nuts as the drifty wheels are thin holes:
Bought some drifty 18's...will be using these on the road while the one wheel is being repaired:
And this which will be fitted when the snows pisses off. ACT 6 paddle clutch rated to 600 ft/lbs of torque:
Short term plans are:
- Achieve just under 300bhp by adding FMIC, colder plugs, full service, boost guage and boost controller. Been told the standard ECU can handle 15 PSI which is just below 300bhp on the above setup.
- Fit the car with fully adjustable suspensions (arms & maybe coilovers)
- Fit camber top mounts
Long term goals:
Bring drifting up to drag racing level in SA
Just need to adjust my handbrake and attach the front bumper with cable ties and then I'm ready for it's first drift event at pembrey on 23rd January. I will take it from there as to what I need to do to set the car up for me for drifting.
I then bought this:
So here she is:
Spec:
Silvia 1996
tight viscous diff
Navan spoiler
Long term goals:
