TBO
Posted: Tue Apr 20, 2010 7:33 pm
by nirvash
hey, anyone using tbo management at the moment? just wanted see what the views are on it, and who supplies it in cape town. thanks
Posted: Wed Apr 21, 2010 12:44 am
by nirvash
one more question, of topic but anyway....
will wheels with a 42mm offset work on an s13? ive heard its not good to go past 25mm on a s13? also what are the biggest tires or best tire size to fit to a wheel with a width of 190mm/19cm?
thanks
Posted: Wed Apr 21, 2010 6:45 am
42mm negative or positive offset?
Posted: Wed Apr 21, 2010 7:31 am
by Lindt
I had 40offset 18x8" on my car with no rubbing, 225/40/18's if you go for 25mm ofset and the rims is a bit wide 8"+ it WILL rub and you have to roll the fenders.
Posted: Wed Apr 21, 2010 8:39 am
by RB25SX
I use TBO, they stopped manufacturing, so no new ones available.
Posted: Wed Apr 21, 2010 1:34 pm
by nirvash
negative offset, so dicktator it is then, y does the apexi power fc have to be so $$$$$ :(
Posted: Wed Apr 21, 2010 3:11 pm
by nirvash
so do you think if i stay with a 18" with 8" (200mm) or smaller width wheel it will be fine with the 42mm negative offset, and doesnt really matter bout the negative offset?
Posted: Wed Apr 21, 2010 3:25 pm
by hentiebez
nirvash wrote:negative offset, so dicktator it is then, y does the apexi power fc have to be so $$$$$ :(
power fc is not so expencive compared to what one spend on the motor and rest of the car
Posted: Wed Apr 21, 2010 5:14 pm
by nirvash
i suppose, but when i think that its just one thing for my car its quite an expensive part, i could do alot more with the money and still run dicktator, and still have a good tune, but if i had a bigger budget it would definitly be power fc
if i had already had my motor in i would have saved more n gone for it but on a tight ass budget now
Posted: Wed Apr 21, 2010 8:45 pm
by mario_200sx
If you are going SR20 in a S13 you can forget about running power FC in anyway. Unless you can get a complete loom from a S14 that has not been cut at any place.
Reason for this is that perfect power fc is a plug-and-play system.
Save up some cash and install a decent management system. I had dicktaotr and it works great. However you can get allot more for your money with other systems.
Posted: Wed Apr 21, 2010 9:44 pm
by nirvash
any other sugestions then? to me, money wise as well, dicktator seems the best
