Ca18det switched off while driving
Posted: Mon Dec 07, 2009 9:42 am
by Richard
Hi Guys, I need some help with my CA18det. my car swithced off while driving and now refuses to start.
I checked for spark and there was none. I reconditioned my power transistor, engine turns but still no spark.
There is a small valve below the power transistor that is making a wierd sound when the ignition is switched on that I have not heard before.
Has anyone had this problem? Please help.
Posted: Mon Dec 07, 2009 9:54 am
I think you should check your CAS......
Posted: Mon Dec 07, 2009 10:14 am
by Richard
will do tonight and get back to you.
Posted: Tue Dec 08, 2009 10:37 am
by Richard
I checked the CAS and it seems to be fine, however the pressure regulator solonoid valve below the power transistor is making a pulsing sound and that seems to have an effect on my fuel pump. Fuel pump is also pulsing on and off.
Posted: Tue Dec 08, 2009 10:45 am
Disconnect the power transistor and bypass the vacuum pipes so that all go straight to FPR.
Try then
check fuel pressure.....
Posted: Tue Dec 08, 2009 10:51 am
by Richard
Thanks, will try that tonight.
Posted: Wed Dec 09, 2009 1:26 pm
by Richard
I disconnected the valve under power transistor and re-routed vacuum pipes to FPR, fuel pump and fuel pump relay still pulse.
Posted: Wed Dec 09, 2009 1:53 pm
Richard wrote:I disconnected the valve under power transistor and re-routed vacuum pipes to FPR, fuel pump and fuel pump relay still pulse.
Seen something like this on Wicked's car, ecu was fuuuuked.
Posted: Wed Dec 09, 2009 2:49 pm
Try direct power from acc2(ignition) to a new relay and wiring for fuel pump....or give fuel pump direct fused power to see if the pump is functioning or not....if it is, check relay....if thats ok....check ecu
Posted: Thu Dec 10, 2009 9:47 am
by Richard
Thanks Bud, will try that.
Posted: Mon Feb 08, 2010 12:38 pm
by Richard
Finally got back to working on my car, I checked the fuel pump, direct power and it seems fine. I now assume it is the ECU. Is there anyone that can check my ECU out as I have no clue how to check it.
Posted: Mon Feb 08, 2010 12:41 pm
I have a ECU for you, if you want, lets try it, if it works you buy....
Posted: Mon Feb 08, 2010 12:52 pm
by Richard
Where are you and how much? I'm in Florida JHB
Posted: Mon Feb 08, 2010 12:54 pm
I'm in Centurion Erasmuskloof, cheapest youl ever get R400
Posted: Mon Feb 08, 2010 12:57 pm
by Richard
Call me or can I have your no. mine is 083 5488 400
