Headlight
Posted: Fri Dec 04, 2009 7:19 am
So....I've had a problem since I got the S13.....
the right hand side(driver) headlight works, when you put it on bright it goes off, the left hend one works fine, I checked fuses and all....unless there is fuses or relays I don't know about....checked the manual....but I am not a electrical picture boffen......so that did not help me at all...
help?
Posted: Fri Dec 04, 2009 7:23 am
Thought you fixed that already?
Posted: Fri Dec 04, 2009 7:32 am
I thaught it was.....but it wasn't, normal light works, as soon as you go bright it dies.....just the one....
Posted: Fri Dec 04, 2009 7:57 am
If you go to bright does the blue light on the cluster come on?
Posted: Fri Dec 04, 2009 7:58 am
by poizen
just change globes
Posted: Fri Dec 04, 2009 12:40 pm
No the blue light does not and I have tried changing the globe....
Posted: Fri Dec 04, 2009 3:27 pm
by ljS14
Had this problem on my S14,Took it to the auto elec and my SWITCH was faulty,These cars are complicated and run parellel on the switch for the lights(or somthing like that
He fixed it while i was waiting,Thought i was going to have to buy another switch but its simple if you know what you doing
I dont thats why my local Auto elec helped me.
Posted: Fri Dec 04, 2009 3:32 pm
Thanks to all for the info....I'll try ansd sort it this weekend.
Posted: Fri Dec 04, 2009 3:34 pm
by ljS14
Im 100% sure its your light switch
Good luck Draco and hope you come right .
Posted: Sat Dec 05, 2009 7:40 pm
by ChemCool
ljS14 wrote:Im 100% sure its your light switch
Derek, my sx is exactly the same...call me on this one, yes we need to open that switches again.last time around it was the dash lights off.
Chem
Posted: Mon Dec 07, 2009 7:23 am
Ok....I have sorted it.....
If you take the whole switch out there is the almost see through cover on the back, take it off, there is 5 copper plates, when you put on the lights the middle one goes down and makes contact with the 2 right ones, when you put on the brights the 2 right ones go up and the 2 left ones goes down....if eather one of them don't make contact your brights won't go on or off
PS....sides mentioned is when copper plate contacts show towards you.
Posted: Mon Dec 07, 2009 7:24 am
Chem
Hi Freddy, sorry saw the post this morning, but we spoke over the weekend, if you need some help please let me know!!!!
