Aircon-Bridge
Posted: Fri Oct 30, 2009 8:02 am
So you've got a after market ecu and your air con isn't working, no sweat just connect pin 6 G/Y to pin 46 L/G(on the main ecu plug) and everything is cool. The only catch is that the air con wont switch off when you put foot like it does(or suppose to do) with the std ecu. If you're running something like a xms with set points you can use this with a NC relay to accomplices the switch off effect under certain conditions.
Posted: Fri Oct 30, 2009 9:04 am
by Tobie
Will that be true for my R32 as well?
The aircon button became sort of the race switch in my Renault. lol
Posted: Fri Oct 30, 2009 9:17 am
I'm not sure bout the pin out on the R32 but it should work the same. The ecu just activate a fast idle when the air con is switched on and cut the air con when more power is needed.
Looks like pin 9 and pin 46 for the R32 Tobie.
Posted: Sat Dec 05, 2009 7:51 pm
by ChemCool
Charl, I must really try and resolve this one, mine aircon also down, but i rember y said the stock harness is involved?? I need the aircon man!
Chem 8)
Posted: Mon Dec 07, 2009 3:47 pm
ChemCool wrote:Charl, I must really try and resolve this one, mine aircon also down, but i rember y said the stock harness is involved?? I need the aircon man!
Chem 8)
Call me, we'll sort it.
Posted: Mon Dec 14, 2009 8:00 am
I would like to thank Charl, he sorted my aircon this weekend, in the end it was not that easy because my standard wiring was a mess.....but after scratching the head for some time and a good deal of on...ja.....off....ja....on....ja it was sorted.
Thanks Charly
