Oil Pressure UP - why?
Posted: Fri Feb 09, 2007 8:34 am
by ChemCool
Overnight early this morning my eye caught the oil pressure gauge reading 1 to 1.5 Bar more than usual. When normal driving hot engine and during idle the ratio is also up. Question - why? What causes this? Do you ppl think it tells me to change oil. I was on my way buying new oil because it is time to do it anyway. But if you agree with this one, then the oil pressure meter tells me more than just oil pressure? Is there anything else we need to know about oil pressure up all of a sudden overnight? What is on its way to break down?
Posted: Fri Feb 09, 2007 8:49 am
Not sure if the sx has this but the old Alfa's have a bypass valve in the oil pump which they used to control the oil pressure. Now these were prone to getting stuck either closed or open, either high pressure or low pressure and it would never change.
Just a thought 8) .
Posted: Fri Feb 09, 2007 9:00 am
by WooHaa
I think you should double check that gauge.
Maybe the gauge is faulty, & over reading.
Check the send unit as well.
Posted: Fri Feb 09, 2007 10:45 am
by Charl
Gary57 wrote:Not sure if the sx has this but the old Alfa's have a bypass valve in the oil pump which they used to control the oil pressure. .
there is like a flat face allan head in the oil pump, inside is a spring... don't know if this is that valve?
could some muck have settled overnight in some oil holes blocking them? this would cause the pressure to go up won't it?
Posted: Fri Feb 09, 2007 11:22 am
Ja that could be it, just check the manual and see.
Posted: Fri Feb 09, 2007 5:07 pm
my 2c:
many ppl increase the oil pressure (in many other cars too) by fiddling with the spring in the pump mentioned by charl. that can control the "rate" of the pump (if thats the right word)!
there is also a little ball in a little hole that is sprung in the oil filter housing. that controls pressure as far as i know, and could have gotten stuck.
and my best is when ppl use "guessometers" because they are more affordable!!! now dont get me wrong, because i also have guessometers, but it could well be that. try to get a different sender of the same brand, to see if the reading changes!!!
so i've repeated what everyone else has said!!!, just dont call me a cockmonkey!!!
Posted: Sat Feb 10, 2007 10:38 pm
by Charl
Just for interest sake, that is a regulator valve
Posted: Mon Feb 12, 2007 8:45 am
by nad_200sx
BTW, if the regulator vavle on a Nissan oilpump get stuck somehow, the oil filter will not be able to handle the pressure and will pop right off! Happened to my previous S14 once! This was on a brand new NISSAN pump!
Posted: Mon Feb 12, 2007 4:42 pm
by ChemCool
After a week since, the gauge is now reading anything he wants. Just eratic. I think the gauge and or sender unit is then suspect.
And then it means these Autostyle gauges are rubbish. It will be my second one in 6 months time. First it was Boost gauge now this Oil Pressure Gauge. They look smart and fit the cockpit, but that is all. No good.
Thanks to all.
Posted: Tue Feb 13, 2007 11:48 am
expensive gauges from japan - deFi, Greddy, HKS!!!
or
expensive gauges from Germany - VDO.
the jap ones look pretty, the VDO's dont really!!!
its your choice!
Posted: Tue Feb 13, 2007 12:41 pm
by ChemCool
or
its your choice!
Goedkoop koop is duur koop! :( :(
Posted: Tue Feb 13, 2007 12:45 pm
i'm also finding that out the difficult way with these blarry guessometers!!!!
