greddy airinx
Posted: Wed Jul 15, 2009 11:14 am
by poizen
hey guys i just bought a greddy airinx airfilter now was wondering where to mount it
should i mount it where i have my cone filter mounted now
or
should i put it back to the org position
and last i know it a dry filter but me doing motorcross its imbeded in my brain that a foam filter must have oil so should i oul this filter or not
Posted: Wed Jul 15, 2009 11:53 am
by ReeceZ
original position and take the headlight out :D
Posted: Wed Jul 15, 2009 11:57 am
by Sparco_pro2000
do it where i did mine
[/img]
Posted: Wed Jul 15, 2009 12:19 pm
by poizen
Sparco_pro2000 wrote:do it where i did mine
[/img]
where bud the pic never came up
Posted: Wed Jul 15, 2009 2:21 pm
by poizen
my other option is make a funnel that will fit in the opening from the bumper and direct the air thru a tube to a sealed box where the air filter well sit what you think guys
Posted: Wed Jul 15, 2009 2:39 pm
by phoenix s14
The latter option is alot more work but I would surely rather do that... honestly if a stone comes down the road and smacks the filter it will go to pieces if it is in the bumper...
Posted: Wed Jul 15, 2009 3:19 pm
poizen wrote:my other option is make a funnel that will fit in the opening from the bumper and direct the air thru a tube to a sealed box where the air filter well sit what you think guys
yip this one
Posted: Thu Jul 16, 2009 7:38 am
by Speed breeder
too low - you will suck up water when it rains... don't know if you drive the car daily... it sounds this way...
also down there colder air but more dust
funnel and closed box - just as long as the funnel isn't restrictive and the box gets enough airflow.
Posted: Thu Jul 16, 2009 3:31 pm
by poizen
ok so i put the filter back to old place and then i needed cold air in there so i came up with a temp plan till i have the whole weekend to play around
so here the front port it was ment to be a funnel on across the whole hole but i ran out of time so will build a better one this weekend
here the pipe just straight forward
and here where the air delivers to
and the filter in and the air in theory sholu rush right in front of the filter and be like havving a hunters on a hot summer day*refreshing*
Posted: Fri Jul 17, 2009 9:32 am
by phoenix s14
I would also close off the filter from the engine bay. This will keep them hot under bonnet air away too... Lookin good there bud... I would for airflow purposes ad a bell mouth to both ends so the air flows nicely...
Posted: Fri Jul 17, 2009 10:54 am
by poizen
yes im still going to do all that the bumper vent not finished in going to seal off that whole front port then ill try fad a box to go around the filter and seal in to the cold air
Posted: Sat Jul 18, 2009 12:05 am
make an exit vent for that "sealed" box.
a wise bunny i know keeps chooning me about pressure differences, and i usually dont listen, but i cant get that phrase out of my head anymore! it applies to everything!
Posted: Sat Jul 18, 2009 11:37 am
by poizen
well it wont be completly seald it just going to shield 90% of the heat from the engin bay
Posted: Thu Jul 30, 2009 5:05 pm
by Sparco_pro2000
