Posted: Fri Jul 10, 2009 11:01 am
can someone please explain the compound ratings, and where to get a list of them for different tires?
https://forum.sxoc.co.za/
Let me deal with the easiest one first.veecee wrote:can someone please explain the compound ratings, and where to get a list of them for different tires?
okGuy wrote:My Pirelli P6000's on my old Alfa were 140 or 180 UTQG rating and that is hardly a soft compound.
The Toyo R888 Semi slicks I use for autocrossing are 100, and I'd consider anything harder than that to be a road tyre. That Federal hardly looks like a semi slick either compared to the Toyo's or the Bridgestone semis.
A true semi slick is night and day difference in grip and cornering, and they're not bad in the wet either (Toyo R888 is listed by Toyo as a wet weather race tyre) The only problem's are the semis wear quickly and are very noisy, low frequency tread noise.
It's not really that techie./..is it? I kinda expected lotsa people to know that...veecee wrote:yeah thanks dude...
maybe one of the more bored and less lazy mods can move that to the tech section?
YES! Most companies use it a marketing ploy....others use it as guideline..the problem is that it's never really governed...you know ...really really governed..I mean SABS would really be a worthwhile entity IMO if....they tested manufacturerers claims. Guess that would cost but it would be be better.Gary57 wrote:Problem is tyres arent tested by an external company like crash tests are. Each company that manufactures the tyres rate them and its basically a rating or 1-3 which is very crude.
My Toyos handle FAR better than my Yokis or Michelins did but all 3 had the same traction, temp and wear ratings.
I have the Dunlops Sport 6060.. whats your take on those tires. From my experience they a bit noisy but its the first tym I fitted 18's on.Gary57 wrote:It just shows that it has a good tempreture rating just not a very good traction rating, AA A is ideal.
it's an average rating...but as I mention all these are relative....if the tyre is advertised as a long life, passenger tyre then you see ratings as high as 420, ultimate grip might suck. It all depends on how manufactures tend to produce their range of tyres.poizen wrote:sewercyde my tires are 280 a a is this a deacent rating
