RB GEARGOX
Posted: Wed Jun 17, 2009 12:46 pm
by godzilla
iam looking for a box to mate up to my Rb20.i was told that a CA18 will fit directly can anyone confirm this? I was gonna go the 21R box but still need a bell housing, what else will work and still have good ratios,this will be used (abused) in drifting,burnouts, dounuts, gymkhana etc.....
I have a VG30 backie box( strong as hell) but the bell housing cant seperate from the box???? so my options are.....
get rb box - very expensive
CA18 box- might not work or need a bell housing
21R box - still need bell housing
Swop out internals of vg30 into a workable casing?!!?!?
get new eraskyline box- manual boxes are scares?!?!
help?
AND can a ca18 box work on aN SR20 and vice versa???
Posted: Wed Jun 17, 2009 1:00 pm
by widowmaker
say again? i missed that part about the gearbox
Posted: Wed Jun 17, 2009 1:08 pm
by ljS14
Depends on how much power the motor is pushing out,
The RB20 box can only handle up to 300wkw,Thats were mine broke :oops:
Have the RB25 fat box now ,Bullitproof :wink:
If below 300wkw ,Any import place can help you with a RB20(thin box).
The CA18 and SR20 boxes but wont take over 300wkw.
You should be able to mate the fat RB25 box to the engine if the RB20 box fitted as they are interchangable ,That will be the strongest option ,They cost R6500.00 at any import shop,The lenth of the fatbox is 800mm,thats the one you want ,I know its expensive but its worth it as you wont have anymore hassles with broken boxes.
Posted: Wed Jun 17, 2009 6:04 pm
by DKSA
i have a gearbox from a skyline 2.0gle....the motor is a ca20 but the gearbox is identical to the rb20e box, just different bellhousing..
where are you located?
rb
Posted: Thu Jun 18, 2009 9:03 am
by godzilla
the motor will be fairly stock,.6boost max,will only be running RB25turbo,and freeflow exhast,but definatly under 220kw,im not looking at high power figures. R6500 is alot for a box,ill spend that when i go Rb25 or26 in the future,I am in capetown at the airport,ill definatly look at a old skyline box...... thanks guys
gearbox
Posted: Thu Jun 18, 2009 10:06 pm
by emile v s
got sr20 box. in c t
Posted: Thu Jun 18, 2009 10:34 pm
by DKSA
you can take my box for 1,5k... i may be able to find a bell housing for you here in pe
Posted: Fri Jun 19, 2009 7:56 am
any box expect the rb is going to need a bellhousing
Posted: Fri Jun 19, 2009 1:19 pm
by DKSA
yeah but the box itself is identical to a rb20 box
Posted: Fri Jun 19, 2009 1:21 pm
DKSA wrote:yeah but the box itself is identical to a rb20 box
the CA20E? Give it a try
box
Posted: Mon Jun 22, 2009 2:43 pm
by godzilla
Thanks guys,i got a box,will be getting it wednesday,a buds connect got one for a gd price,rb20 box.but atleast i know what els i can use WHEN i f@Ck it up........hehehe
Posted: Mon Aug 17, 2009 9:39 am
by Trapstar
heyta guys
gudday
by Trapstar
heyta guys
Re: gudday
Posted: Mon Aug 17, 2009 10:42 am
by ReeceZ
Trapstar wrote:heyta guys
golden lubricata
rb
Posted: Mon Aug 17, 2009 12:30 pm
by godzilla
and as in life the rb box fell through.\BUT i did get a cresida box freerand..heheheh but now the magic question ,what are the differences between 21R and and 18R cresida box?
I have the matching starter if i buy a blank bell housing or a 21R to RB bell housig would i need the cresida starter or the rb starter? and the flywheel story do i leave it std....
just got my new fibre saani fendersfor the front in the process of getting the back saani fenders madeup.....
