				WANTED:CA18DET MAP
				Posted: Tue Jun 16, 2009 11:22 pm
				by STOLEN1ZN
				hi all
can anyone help me with a map for a dicktator 60-2,i have a ca18det with a t28 and fmic,any map for the ca18 will help
many thanks
yash
				Posted: Wed Jun 17, 2009 8:34 am
				Are you sure you are using a 60-2 and not the CAS wheel??
You will only get a basic map it will still need to be tuned.
				Posted: Wed Jun 17, 2009 1:41 pm
				by STOLEN1ZN
				well i just bought a dicktator 60-2 from a guy who had it on an opel ts,i havent wired it yet but i plan on wiring it to the cas,i just need a basic map so i can get it to the dyno or if someone has a tuned map then it would be easier for me.
				Posted: Wed Jun 17, 2009 1:46 pm
				by widowmaker
				sommer net so?
				Posted: Wed Jun 17, 2009 2:36 pm
				The 60-2 box wont be able to run off the CAS, it needs a 60-2 wheel on the crank. Also it isnt a wasted spark box so you will need to send it to agent to get changed to be wasted spark.
				Posted: Thu Jun 18, 2009 2:23 am
				yeah dude - if its a 60-2 tator, then you will need a 60-2 wheel on your crank and a pickup that works with the system.
				Posted: Thu Jun 18, 2009 8:41 am
				by STOLEN1ZN
				thanks,i guess i am fitting a 60-2 wheel onto the crank pulley but is the box not wasted spark.
				Posted: Thu Jun 18, 2009 10:18 am
				You wont be able to use the individual coil packs either then...
