Turbo Info
Posted: Fri Apr 03, 2009 11:02 am
by Drillergy
What turbo comes on a SR20DET motor with an A/R 80, is it the t28 or t25???
I think its the stock turbo.....Its an SR20DET RWD red top.
T28?
T25?
Posted: Fri Apr 03, 2009 11:32 am
t25g
Posted: Fri Apr 03, 2009 12:01 pm
by Drillergy
Found this on Wiki
Nissan SR20DET
The SR20DET is part of the SR family of engines from Nissan.
It is a popular engine coming from a variety of Nissan cars, generally the Nissan Silvia and 180SX. It also came in the Pulsar GTI-R and the Nissan Bluebird. This engine replaced the CA18DE and CA18DET that originally powered the Silvia and 180SX. The CA18 was deemed too expensive to produce and no longer met Japanese emission standards, so it was replaced by the SR20. The SR, just like the out-going CA, was a turbocharged intercooled engine in top form. Nissan also produced a cheaper naturally aspirated version called the SR20DE. In the US and Canada, the Silvia and 180SX are both under the 240SX banner. USDM and Canada 240SX's come stock with the SOHC KA24E for earlier models, or the DOHC KA24DE for later models. Both are naturally aspirated engines producing 140 hp (100 kW) and 155 hp (116 kW) respectively. SR20DET engine swaps are becoming more commonplace due to the forced induction aftermarket additions available for the SR20DET.
The Garrett T25g turbo used on most SR20DET engines.The breakdown of the engine code is as follows:
SR - Engine Code Also known as "senior"
20 - 2.0 Liters
D - Dual Overhead Cam
E - Electronic Fuel Injection
T - Turbocharged
Contents [hide]
1 Origins
2 Valve cover colors
3 List of cars with the SR20DET
4 Engine specification
4.1 Comparison table
4.2 Miscellanea
5 See also
[edit] Origins
The SR20DET was first produced in the U12 Nissan Bluebird 2000SSS Attesa in October 1989[1], possibly as Nissan's rally project. From 1990 through to 1994 it was used in the infamous Nissan Pulsar GTi-R (N14) however with a bigger T28 turbo. In both these cars the engine is aligned in a transverse fashion.
However the RWD Nissan Silvia and Nissan 180SX produced in 1991 were built with a longitudinally aligned SR20DET. Some of the 180SX's were released with the SR20DET while others had the naturally aspirated SR20DE.
The engine then went on to be used in the Nissan Avenir in 1995, the Nissan R'nessa in 1997 and the Nissan Liberty in 1999, although these models did not gain the cult status that the earlier produced models did.
Out of all the Nissan models produced with the SR20DET, the Silvia was the longest running model to use it. The S14 and S15 use a bigger turbocharger than the S13 models.
[edit] Valve cover colors
SR20DET installed in a Nissan 200SX S14.The colors of the valve covers seem to be related to the year the engine was released.
Color Model Years
Red S13/180SX/Bluebird/Pulsar 1989–1994
Black S13/180SX 1994–1998
Black S14/S15 1994–2002
Silver Avenir 1995–2001
S13 Black top - Came from 180sx's post 94 (Garrett T25G turbo)
S13 Red top - Came from S13 Silvia and 180sx pre 94 (Garrett T25G turbo)
S14 Black top - 94-98 Silvias - Variable Cam:0 Timing aka VCT was introduced (Garrett T28 bush journal bearing turbo) Only the JDM engine came with a ball bearing turbo.
S15 Black top - 99-02 Silvias. (Garrett Ball Bearing T28 turbo and 6 speed transmission)
[edit] List of cars with the SR20DET
Model Spec Chassis Years Colour Turbo Market
Bluebird 2000SSS Attesa Limited U12 1989
egg
T28g Japan
2000SSS Attesa Limited U13 91,93 Redtop T3-T4g Japan
2000SSS Attesa Limited U13 1995 Blacktop T52g Japan
Pulsar GTI-R RNN14 90-94 Redtop T3-T4 (Quad TB) Japan
180SX All S13 91-93 Redtop T25 Japan
All (except G/Type S) S13 94-97 Blacktop T25 Japan
Silvia K's S13 91-93 Redtop T25 Japan
K's S14 94-99 Blacktop T28 (VCT) Japan
Autech Version K's MF-T S14 98-99 Blacktop IHI VN14 (VCT) Japan
270R S14 1994
Spec-R S15 99-02 Blacktop T28 (VCT) Japan
Avenir GT Turbo Salut W10 95,97 Silvertop T25g Japan
GT4 W11 98,00-01 Silvertop T25g Japan
Liberty GT4 Highway Star M12 99-00 Japan
R'nessa GT Turbo N30 97-00 Japan
200SX S14 93-99 Blacktop (w/o VCT) Europe
Sunny GTI-R RNN14 90-94 Redtop T28 (Quad TB) Europe
[edit] Engine specification
DOHC (Dual Over Head Cams), 16 Valves, Chain driven cam sprockets
Bore x Stroke of 86 mm x 86 mm
Displacement of 1998 cc (rounded to 2.0 liters)
[edit] Comparison table
Car Engine Compression Power Torque Turbo Stock boost Turbine Compressor
'89 U12 Bluebird Ltd
Redtop 8.5:1 150 kW (201 hp) @ 6000 rpm 202 lb·ft (274 N·m) @ 4000 rpm T-25BB 7psi
'91-'95 U13 Bluebird Ltd
Redtop 8.5:1 154 kW (206 hp) @ 6000 rpm 202 lb·ft (274 N·m) @ 4000 rpm T-25G 7psi
'95-'97 W10 Avenir Salut
Silvertop 8.5:1 154 kW (206 hp) @ 6000 rpm 202 lb·ft (274 N·m) @ 4000 rpm T-25G 7psi
'97-'01 W11 Avenir GT4
Silvertop 8.5:1 169 kW (227 hp) @ 6000 rpm 203 lb·ft (275 N·m) @ 3600 rpm T-25BB 7psi
'90-'94 N14 Pulsar GTi-R
Redtop 8.3:1 169 kW (227 hp) @ 6400 rpm (Euro: 164 kW (220 hp) @ 6400 rpm) 210 lb·ft (280 N·m) @ 4800 rpm (Euro: 196 lb·ft (266 N·m) @ 4800 rpm T-28 10.6psi 79 Trim, .86 A/R Housing
'91-'93 S13 Silvia, 180sx
Redtop 8.5:1 151 kW (202 hp) @ 6000 rpm 203 lb·ft (275 N·m) @ 4000 rpm T-25G 7psi 62 trim 53.8 mm (2.1 in) .80 A/R housing
BCI-1
'94-'98 S13 180sx
Blacktop 8.5:1 151 kW (202 hp) @ 6000 rpm 203 lb·ft (275 N·m) @ 4000 rpm T-25G 7psi 62 trim 53.8 mm (2.1 in), .80 A/R housing
BCI-1
'95-'99 S14 Silvia, 200sx
Blacktop 8.5:1 162 kW (217 hp) @ 6000 rpm 203 lb·ft (275 N·m) @ 4800 rpm T-28 7psi 62 trim 53.8 mm (2.1 in), .64 A/R housing, bush bearing
BCI-1 in T-04B housing
'99-02 S15 Silvia
Blacktop 8.5:1 183 kW (245 hp) @ 6400 rpm 202 lb·ft (274 N·m) @ 4800 rpm T-28 11psi 60 trim 60 mm (2.4 in), ball bearing, Inco turbine wheel
[edit] Miscellanea
Lists of miscellaneous information should be avoided. Please relocate any relevant information into appropriate sections or articles. (January 2009)
1990-1994 N14 Pulsar GTi-R
Compressor Flow: 33 lb/MIN
Injector Flow: 440cc/min Injector
LSD front and rear in RB Model, LSD Rear only in RA
Named Baby Godzilla after the famous GTR Skyline, Boasting similarities in the plenum chamber
1991-1998 180SX, S13 Silvia
Throttle Body Bore: 60 mm
Injector Flow: 370cc/min Injector
1995-1999 S14 Silvia
Throttle Body Bore: 50 mm
Injector Flow: 370cc/min Injector.
