Which Dump Valve Should I fit?????
Posted: Thu Mar 26, 2009 4:01 pm
by Drillergy
Blitz
Smart
RS
SQV
Posted: Fri Mar 27, 2009 9:11 am
by jon
None of the above. Rather go for a fully recirculating diverter valve, like Forge for example. Works wonders for the audi S3 crew.
Edit: If one the above companies happens to make a fully recirculating dv then that should be fine as well.
Posted: Fri Mar 27, 2009 9:26 am
jon wrote:None of the above. Rather go for a fully recirculating diverter valve, like Forge for example. Works wonders for the audi S3 crew.
But it doesnt sound that nice.
Posted: Fri Mar 27, 2009 9:35 am
by Pinkfluffybunnys
That’s because You haven’t heard mine :wink:
Posted: Fri Mar 27, 2009 10:07 am
by Stephen Swanepoel
I bought a TIAL unit.
Wow worth every cent.
but ja you buy about 10 Chinese HKS knockoffs for the price of the TIAL.
check it out.
http://www.tialsport.com/prod_bv_q.htm
Posted: Fri Mar 27, 2009 10:11 am
by ReeceZ
Best recirc valve comes from Go Fast Bits in Australia...mate. If you want the best of both worlds get the GFB Hybrid. Which can run 100% vent, 100% recirc or 50/50, all done by turning a cap on the valve. Only thing is, I'm not sure if you're going to need to run different maps to compensate for when there is air in the system or no air. When last I check the universal hybrid was going for around R2000. but it's one solid piece of engineering. hope that helps
Posted: Fri Mar 27, 2009 10:13 am
by ReeceZ
Posted: Fri Mar 27, 2009 10:17 am
Sounds like a option.
Posted: Wed Apr 08, 2009 8:44 am
so the answer seems to be sqv or a recirc valve might be looking onto changing mine
Posted: Wed Apr 08, 2009 9:29 am
by ReeceZ
Buy the Deceptor Pro from GFB, it's an adjustable BOV that can set from your drivers seat. only R6k :lol:
