PFB SX Cleaning Tips Check-List.
Posted: Tue Mar 24, 2009 4:23 pm
Howzit Guys.
I thought I would write a small check list of things to do once you have bought a 200SX. I know Toby has covered the what to look for when buying a SX .
Most of my suggestions relate to the stock ECU Fueling and idle control Equipment and to the CA18DET.
I take no responsibility for any damage’s that might occur these tips have worked for me in the past.
Most 200SX are more then 10 years old and that’s a lot of abuse from previous buyers. Here is a small list of Items I would check or change on the car after purchase even if you got the car from a Nissan dealer, friend or a doggy garage.
These Suggestions are not cheap you will need to spend a few bucks on you ride but it could possibly save you some money down the road. Some of these suggestions might not be liked but they have worked for me. If you are too scared to fiddle on you new car then only do the items you are comfortable with
Items to be bought: Air Filter (If still stock), Spark plugs, Fuel filter, 2 x Oil filter, Cheap oil, Good Synthetic oil, 4 x tin of Carb cleaner, Ear buds, Sanding paper and Clean Green * Optional - Oil change helper*
Tools: Basic hand tools and Spanners plus a comp tester.
1.) Removed all intake and intercooler piping also if possible remove the Intercooler (The stock Pipes, Turbo and Intercooler fill over time with oil vapor from the PVC system) once removed spray all the piping inside and out with Clean Green along with the intercooler if removed and wash out all piping and the intercooler to removed oil residue also check that the spring in the intake pipe is properly seated once all the piping is clean place in the sun to dry also remove and clean the stock airbox if the item is still there.
2.) Now that the piping has been removed you have access to a few vital area’s, next take the AFM and loosen the two top screws and slide the unit out of the Ali body once this is done spray Carb Cleaner on a Ear bud and proceeded to clean the AFM hot wire there are two wires you need to clean you need to be very careful not to break the wires. The hot wire builds up with dirt and grim over time causing the car to return incorrect readings to the ECU costing you fuel and performance once the AFM hot wires are clean assemble the unit by pushing it little into its housing and installing the screws.
3.) * Note the next suggestion might be frowned upon but it worked for me* Spray carburetor cleaner into the front and outlet of you turbo charger you will be amazed at the dirt and oil that has caked onto the blades and back housing over the years to the hot turbo spray till the liquid is clear. I would blow the remaining liquid out using the cold pipe as a funnel. Carb cleaner will evaporate over time.
4.) Next start cleaning the throttle body with carb cleaner dirt and grim also start to cake onto the throttle body over time as well use a old covered in carb cleaner cloth to remove any dirt caked onto the butterfly.
5.) Next remove the IAA (idle air adjusting unit) located on the side of the intake there are three bolts and you need to remove the hose be careful not to break the gasket it normally sticks to the unit. , Next start cleaning this unit 80% of idle problems are caused by this item being dirty once done reinstall the item.
6.) Next clean the air regulator valve located below the throttle body it has a black cover there is no need to remove this item
*** Next leaving all the pipes disconnected and the AFM unplugged but all idle control devices connected, Start the car, it will be hard the start the first time and you will need to keep the throttle down normal this is where you will see a few clouds of smoke as the engine burns up the oil filled carburetor cleaner, Now spray the remaining carburetor cleaner into the intake to clean it. Remember to keep the engine running so don’t spray too much once you have emptied your current can switch off the engine and reinstall all the piping making sure all the clamps are correctly installed. ***
I will fill in the rest tomorrow
