200sx with supra power 2JZ-GTE R75 000
Posted: Tue Mar 17, 2009 4:48 pm
Hi guys Many of you know I jumped at the opportunity to buy Riaans Project, as i know the time and money he spent,
My project cost me over R110k and does not even come close to the addtional parts that are included in this deal
My Rx7 hasnt been sold yet, not even sure if this will get sold, but it has put me under some financial pressure
This is a incomplete project, but fairly simple to complete and should cost nothing more than 15k to finish up even less according to my calulations
I have added approx cost as to what certain parts cost me and to what certain parts are valued at, Please understand its approximate costs
1993 200SX S13 with no accident damage ( R30 000) atleast
im told the body is very neat and clean
Toyota Supra 2JZ GTE Motor (R15 000 ) import motors are auto and therfore need Flywheels and clutches kits
Supra R154(Big) gearbox. (R 6000)
Thats what i paid when i bought them for my car
the motor and gearbox is fitted. ( R3000)approx cheap labour cost, including making up mounts
Included in the sale is the following:
Items marked with an * are brand new
*Toyota piston rings
*Toyota big end and main bearings
*Toyota complete gasket set (oil seals included) for engine
*Toyota electrical connectors for fuel injectors, coils, starter etc
*Toyota factory valve stem seals
probally worth over R5k
*Toyota water pump (R1500)
*Toyota oil pump ( R1700)
*Toyota cam belt (R360)
*T72 turbo ( R5000)
*S/S turbo branch ( R2500)
*Tail 44mm waste gate (R1600)
*HKS SSQ blow valve (R 2000)
*HKS 1.6mm steel head gasket (R3000)
*600x300x76mm intercooler (R1600)
*S/S boost pipes with silicone hose (R2000)
*50mm aluminum radiator ( R2500)
*Toyota thermostat (R550)
E Boost 2 boost controller (R5000)
K&N air filter (R 400)
Toyota factory flywheel (R8000) brand new when i called for a price
clutch and pressure plate ( R3400)
76mm S/S exhaust ( R2000)
X Force tail box (R3000)
LM1 air fuel ratio meter with oxygen sensor (R3500)
and more. like engine covers and small bits
Needs
modified prop shaft , mine cost R800 balanced
F/M system Dickataor R3500
electric radiator fans R1000 with relay
some re routing of wiring in engine bay, re routing of brake and clutch piping and a few other items.
The more i look at this the more i want to kick myself
Call me if you interested
Donny
0833039449
*T72 turbo ( R5000)
Needs
Donny
0833039449
