i cant believe you two knobdonkey's didnt call me!!!Vlade wrote:Yeah I must say it went well next is the rest of the engine... LOTS OF WORK REMAIN Lots and Lots...
Toby got to sort some stuff out before the engine is done
* Injectors
* Alternator
next time i'm feeling generous i will have to check myself... i guess it means i will get my shit back soon though!!!
good luck tobes.
- Toby
- Club Founder
- Real Name: Toby Kurien
It's about R6400. Off the top of my head (no pun intended):
- engineering of head
- engineering of block
- engineering of crankshaft
- new bearings and piston rings
- new bearings for conrod small end
- new pistons
- manifold skimming
- new manifold nuts
- all the odds and ends I mentioned and new timing belt
- gasket kit
There are more expenses to come. Hopefully not "school fees", as Calibrator calls it.
- new pistons
- manifold skimming
- new manifold nuts
- gasket kit
- Vlade
- * - Club Pimp - *
- Real Name: Barend
I'd say about same as stock, not more, not less
If you plan to do a motor to handle some performance upgrades I'd say go for some forged ones.
VeeCee has some Arias forged pistons that are from a honda motor, they needed to be modded but so far its the cheapest I've seen PM him for details... Think the price now is R3800
I'll post details soon how to get your CP pistons from the states as soon as mine arrive, that and a full cost break down.
- Toby
- Club Founder
Yea guys, please bear in mind that my rebuild is all about reliability and not power. I will only be running stock boost, etc. on this engine. No mods unless necessary (e.g. the pistons only because I had to rebore the cylinder). Even if I had to put a bigger turbo, I would turn down the boost to keep the boost standard.
a bigger turbo at standard boost, will still put strain on them pistons and rods because you're pumping more air in there!!! remember you should also be concerned about the turbo's rated CFM at specific boost pressures.Toby wrote:Even if I had to put a bigger turbo, I would turn down the boost to keep the boost standard.
and vlade, the pistons are from arias, not from any old crappy honda. they're just a similar design to the honda ones, so they work in our sx motors!!!!
Kewl Veecee do you guys have a place where you buy your parts from like a website link or something. I want to get a brake down on what kinda powa i can get with what kinda investment
ex. kadett 1.3 ls
ex. kadett 1.4 s
ex. kadett 1.8 glx (slightly modded)
ex. kadett big boss turbo
ex. Blue Nissan 200sx 93
ex. White Nissan 200sx 92
ex. Red Z32 Nissan 300zx TT 91
Nissan 200GXI
Corsa Lite 1.4
ex. kadett 1.4 s
Nissan 200GXI
Corsa Lite 1.4
