Where can I get boost pipes made up
Posted: Thu Oct 30, 2008 9:09 am
by Speed breeder
Hi everyone, looking for a good place to have boost pipes made up for the new location of my FMIC.
Preferrebly someone in the Joburg area.
Also I am keeping my boost pipe before FMIC between 50mm - 75mm and after the FMIC between 70 and 75mm.
Posted: Thu Oct 30, 2008 9:54 am
by Drillergy
Did you try Jrs Exhausts on Ontdekkers, they should help, they have the equipment for 76mm madrel bends.
Posted: Thu Oct 30, 2008 10:03 am
by Speed breeder
Thanks D will check it out.
Posted: Fri Oct 31, 2008 7:24 am
by antman
Hi, I was qt JR exhaust on saturday and he quoted me R900 to make up and fit in any size in stainless and another R300 or so to polish the pipes. He did say that I would have to clear the route ie. relocate the battery and cut all the holes, fit the FMIC, basically all he will do is cut, bend and polish and fit the pipes. Make sure that you are happy that there is no debris, filings etc in the pipes before you start up.
Posted: Fri Oct 31, 2008 7:28 am
by Speed breeder
sounds promising... thanks guys...
So just need to start the monster up this weekend without the boost pipes, and take it there next week...
Posted: Fri Oct 31, 2008 8:56 am
Will it start without boostpipes?
Posted: Fri Oct 31, 2008 8:57 am
by Xavier
No
Posted: Fri Oct 31, 2008 9:00 am
by Speed breeder
Yip... Just don't expect anything fantastic...
Connect the filter directly on TB. Its like running the car without boost...
AFAIK - nothing wrong with this.
Posted: Fri Oct 31, 2008 9:48 am
Hy gaan nie start nie my maat, het al getry.
Posted: Fri Oct 31, 2008 11:12 am
by Speed breeder
I will let you know on Monday. I have done this previously without effort though... boost pipe came loose and I did not have the 200sx survival kit in the car - screwdriver...
Posted: Fri Oct 31, 2008 11:18 am
by Drillergy
Yea, I had a boost pipe blow off as well, Didnt run efficiently though.
I thought I blow the turbo, but the pipe just came off.
Also make sure you clean the pipes. :arrow:
Posted: Tue Nov 18, 2008 2:31 pm
by Speed breeder
Sorry...forgot to post about this...
The car started on the first turn and it was possible to adjust fueling etc...car running very smoothly
I will be taking it for the boost pipes shortly.. and driving it there without the boost pipes ... 0 boost.
Posted: Tue Nov 18, 2008 2:39 pm
by ChemCool
Speed breeder wrote:Sorry...forgot to post about this...
Off topic, but will you be at the Rockraceway? And the family?
Chem 8)
Posted: Tue Nov 18, 2008 2:45 pm
by Speed breeder
Hello Oom Chem... will see... just a bit busy trying to fix house and SX at the same time... will check the events listed... If i come the whole crowd will follow... everybody likes this sliding sideways crap afterall...
Posted: Tue Nov 18, 2008 3:53 pm
Drillergy wrote:Y
I though a boost pipe popped off... but alas... my turbo blew....
