Experiments with injectors
Posted: Fri Dec 22, 2006 4:29 pm
Does anyone in Joburg/Pretoria area have bigger injectors that I can use to test remapping my ECU? Also, if anyone is available and keen, and you have a stock ECU and stock injectors, I'd like to try my ECU in your car to see if the map I have is better than standard, and whether or not it will work on standard injectors.
If I can get the mapping right for bigger injectors, than I can map anyone's standard ECU to handle bigger injectors (like 550cc).
