Release bearing gone noisy
Posted: Thu Aug 28, 2008 8:04 am
by Driftmeister
hi guys
i recently noticed my release bearing is becoming noisy
is this an issue i need to attend to asap or what should i do ?
Posted: Thu Aug 28, 2008 8:35 am
by Daniel
Well im not sure how bad it is...but mine was noisy for 20k before i took it out and everything looked pretty good still
eish
Posted: Thu Aug 28, 2008 9:46 am
by Driftmeister
Mine started 5k ago
its not too noisy but i notice it
and when you did yours did you do the clutch as well ?
Posted: Thu Aug 28, 2008 3:45 pm
by Daniel
No clutch was fine still...it was actually a new thrust bearing that got noisy about 1k after installing the new clutch...I only bothered checking it since i had the engine out again anyway
Posted: Fri Aug 29, 2008 12:09 pm
by ChemCool
Daniel wrote:No clutch was fine still...it was actually a new thrust bearing that got noisy about 1k after installing the new clutch...I only bothered checking it since i had the engine out again anyway
This also happened to mine. It is still noisy and it can now stay noisy
Chem
