SMT 6 Piggy-Back
Posted: Sat Dec 09, 2006 8:35 pm
by Deens
Hi, is there anyone out there that has sucessfully installed the Perfect Power SMT 6 piggy-back chip? I have a guy down here in DBN that is struggling. The fueling is no problem. He can't seem to get the correct signal for setting the timing. Any help will be appreciated. PS. he has been talking to the chip guys up in JHB. So far no luck.
S13
Posted: Sun Dec 10, 2006 10:25 am
by The Calibrator
I have installed a few and a shitload of Unichips. How has he connected the rpm inputs and outputs into the smt6? Oh yes what car is it?
SMT 6
Posted: Sun Dec 10, 2006 11:16 am
by Deens
Nissan 200SX S13 - 1.8T
He is struggling to connect the RPM signal. Can I get this guy to call you? Please if you don't mind...he's had the car since Teusday last week. If you agree, please PM your contact number and I will pass it over to him.
Posted: Mon Dec 11, 2006 6:44 am
by The Calibrator
Has he spoken to the guys at Perfect Power? I suggest giving Peter or Godfrey a call on 011 791 5947.
Posted: Mon Dec 11, 2006 9:05 am
by widowmaker
www.thecalibrator.co.za - that you? Are you closing/going away for the 'olidays? Would like to come and chat...
Posted: Mon Dec 11, 2006 9:45 am
by The Calibrator
Yep thats me and I will be around over the silly season. Give me a call before you come through as I will be doing some running round.
Posted: Mon Dec 11, 2006 12:03 pm
by Toby
would you be able to check out my injectors and match them up for new ones?
SMT 6 Piggy-Back
Posted: Mon Dec 11, 2006 4:15 pm
by Deens
He is speaking to Peter as far as I know. Up until Friday he was not able to solve the problem. The last I heard was that Peter was going to install a chip onto a friends 200SX and see if he gets the same situation. Maybe there is some trick in wiring up the RPM signal that you know of?
Posted: Mon Dec 11, 2006 9:59 pm
by The Calibrator
Hmmm its been awhile since I did a S13 so I cant remember which wires I used. However to the best of my knowledge none of the piggybacks understand understand the CAS signal and they all interrupt the signal out of the ECU to the ignitor.
The problem with the S13's is they run individual coils so there are 4 wires out to the ignitor.
There is a solution as I have chipped them in the past and they work well.
As a suggestion I would try interupting the cam reference wire going into the ECU this should allow the timing to be changed.
So find the correct wire cut it and join pin 20 on the SMT 6 to the engine side and Pin 8 to the ecu side.
I dont do injector testing. Why do you want them changed?
SMT 6 Piggy-Back
Posted: Tue Dec 12, 2006 6:13 am
by Deens
Thanks very much. I have printed out your last message and will show my guy what you suggested.
Posted: Tue Dec 12, 2006 7:40 am
by Toby
need the injectors changed cos they are injecting fuel into the engine bay!
Posted: Tue Dec 12, 2006 1:15 pm
by The Calibrator
Ah yes the rare manifold cooling injector however it can in an instant become the exhaust heating injector shortly followed by the lets braai on the bonnet phase.
Posted: Tue Dec 12, 2006 3:05 pm
by widowmaker
TURN THEM AROUND TOBY - QUICK!!!
