Front hub
Posted: Fri Mar 28, 2008 11:35 am
by HancoB
Hi guys I'm looking for a right front hub for my sx. The wheel stud is broken.
Posted: Fri Mar 28, 2008 12:38 pm
by Hotstuff
no need to replace the hub... just buy the stud from Nissan, its about R7-00 each.
It has splines in the back that slot into the hub from the inner side of the wheel. See 240sx forums for diy replacement thereof...
Posted: Fri Mar 28, 2008 2:34 pm
by HancoB
Ah wicked cool thanx man!
Posted: Fri Mar 28, 2008 3:35 pm
by Hotstuff
...and if those useless sales persons at Nissan say they dont have stock... Ask for ones that'll fit onto a Maxima. Same part number as that...
Posted: Fri Mar 28, 2008 3:49 pm
by HancoB
Thanks man that saves my a hell of a lot of money!
Posted: Fri Mar 28, 2008 3:59 pm
by Hotstuff
now you can spend the extra cash on all the finishing touches of your cars flush job...
Posted: Fri Mar 28, 2008 4:13 pm
by HancoB
I think I'll use that to lower the car...but I dont just want to drop it with a dress up kit that cost R1200 and then still you sit with stock dampers and bad handling...How much is the cheapest coil over kit...and dont say TEIN...coz I'll smack your voorbarige lilly white arse...I dont live in Zim and i'm not a billionaire!!!!
Posted: Fri Mar 28, 2008 4:49 pm
HancoB wrote:coz I'll smack your voorbarige lilly white arse...
ROFL - hey hotstuff, now you're a wit-ou!!! hahahaha!!!!
there's nothing wrong with a tein dress-up kit and stock dampers!
but you try calling steve hurley at koni. they do a decent set for about 7 grand.
then again - you could do the eldorado thing like i did, and get over 1 lateral G around corners!!! but when your driving skills improve, you'll realise that although it works - its not ideal!
Posted: Fri Mar 28, 2008 5:55 pm
by Ero_sennin
I bought them at the Nissan dealer for R34-00 each, front ones are very easy to replace, they always just order from the factory for me. takes a day then it is ready for collection.
Posted: Fri Mar 28, 2008 6:39 pm
by Hotstuff
No way dude... Go and order the stuff from Motordeal Nissan on my side of the world...
Posted: Fri Mar 28, 2008 6:44 pm
or you guys could order from any decent nuts and bolts place. wheels studs are a standard issue item, just take the thickness (which i think is 12mm), and the length (cant remember) and the thread pitch (which is either 1.25 or 1.5).
the last thing you need to worry about is that it has to be a high tensile item.
the last time i priced them they were about 8 - 12 bucks each!
Posted: Sat Mar 29, 2008 12:00 am
by HancoB
Coolness man, i'll give the incompetent nissan sales person a ring on Monday!
Posted: Fri Apr 04, 2008 9:14 pm
by HancoB
Nope VC not 8 - 12 bucks...its nissan....R23,24 and for a half moon seal R34,67
Posted: Fri Apr 04, 2008 9:32 pm
if you had read my post properly, you would see that i said it was 8-12 bucks for a high tensile wheel stud at any reputable nuts and bolts store! not nissan.
and i've built enough ca18's to know that the rubber halfmoons are 34 bucks!
Posted: Fri Apr 04, 2008 9:34 pm
by HancoB
Still. Thats madness! Its a piece of rubber as small as you thumbnail and they charge you that...
