What injector???
- Charlvdw
What injector???
Hi all.
I fitted a somota cone filter yesterday and nou the cars going worse again, should i take it back to the dyno or what? Back to toppic, ive noticed a lot of feul is lying on top of my intake underneath the injectors so obviously they are leaking witch i think can be half of my problem. The question now bothering me is if i replace them witch size do i go for seeing that i yust have the filter, zorst and unichip. I dont think ill be doing much more than that to the ca settup.
Thanx
Thanx
unless you can modify your management you should stick with the same size injectors.
and...
if you have a fuel leak like that then you should definitely invest in a FIRE EXTINGUISHER.
its kak watching your car burning down on the side of the road! and murphy likes to pick on us SX owners!
and...
autozone, midas, builders warehouse for fire extinguishers. go for a 1.5kg one at a minimum.
stock injectors are 370cc.
if you can upgrade (have editable management) then rotary injectors are a direct fit and are 550cc. very nice upgrade!
veecee wrote:...if you have a fuel leak like that then you should definitely invest in a FIRE EXTINGUISHER.
at least I could find a pic of a SX on fire!!
I got one at game for something like R150... Fits nice in the passenger footwell....Charlvdw wrote:So whats the standard injectorsize for my ride? O and do you have a contact for FIRE EXTINGUISHERS(smallish lack of space).
