				Skimmed Head??
				Posted: Thu Jan 31, 2008 8:55 am
				Hi guys
I think my head has been skimmed a bit over eagerly. Any solutions? The guy at dastek also rekons so cause if you boost more than .7bar the car starts to detonate.
				Posted: Thu Jan 31, 2008 8:57 am
				by Daniel
				Whats the timing set to?
You could buy a thicker MHG than the standard size, just dont ask me where
				Posted: Thu Jan 31, 2008 9:04 am
				How does a copper head gasget work on these cars?
				Posted: Thu Jan 31, 2008 10:02 am
				did you do a compression test.....compare yours to what the manual says...
				Posted: Thu Jan 31, 2008 10:05 am
				by Doctor G
				time for water meth injection
				Posted: Thu Jan 31, 2008 10:12 am
				I dit do a comp test and its a bit lower than the manual say, but they are all the same. Dont trust the gauge that much thou.
"time for water meth injection"???? [/quote]
				Posted: Thu Jan 31, 2008 10:28 am
				If your compression is lower than the manual I would not say that is your problem....I suspect it is a bit lower than the manuel says....so even if the guage is not on the dot it is not a big factor.
				Posted: Thu Jan 31, 2008 11:06 am
				by Daniel
				I actually have the same problem, comp readings are way low, but even on all cylinders.
havent tried another gauge yet though and i did it with a cold engine wich affects results. I 1st need to sort my radiator problem and then il move onto that
				Posted: Thu Jan 31, 2008 11:17 am
				Me and freddy also got low readings, I don't know what his is reading now but mine read the same after my rebuild.....
				Posted: Thu Jan 31, 2008 11:23 am
				My car just goes kak, acording to the dyno printout it whent from 105kw @ 5500rpm before the chip to 132kw@ 6000 after. I belive thats on the wheels.
				Posted: Thu Jan 31, 2008 11:51 am
				by Phinx
				Is there a Dyno graph for before and after?
				Posted: Thu Jan 31, 2008 12:06 pm
				Yes there is. Thats where i get the info from.
				Posted: Thu Jan 31, 2008 12:08 pm
				Actually that is spot on for the amount of mods you got....what mods you got?
				Posted: Thu Jan 31, 2008 12:19 pm
				Post the dyno sheet.
				Posted: Thu Jan 31, 2008 12:22 pm
				57mm xhaust,unichip. How do i post the sheet?
